Recommendation on running boards please
VXC
I just picked up a 2012 SR5 in Blizzard Pearl and will need some running boards for the wife and baby. Does anybody have any recommendations? I dont know much about them.
Maybe someone can list out a few brands and options I have?
Thanks in advance!
Can't recommend a product, but I will say they are really useful. I originally got them 'cause the wifey is short, but I use them every time I'm in/out.
I like my stock Trail steps. They really match the vehicle. Not sure if they will fit on a SR5. They were around $300 with a discount coupon. Maybe stock SR5 steps? They may be a little more expensive though.
My wife and I own a 2010 BP Limited and we bought a set of running boards from Dee Zee (NX Series). I forget the name of the online store we bought them from, but I recall paying around $400 total. I opted to not get the OEM boards because the limited toe space, as reported by many owners. The Dee Zee boards have ample toe space and there is even a tad bit of adjustability (forward, backward, in and out). Installation was a snap and they are holding up well...your seats will thank you because they take less abuse with the addition of the boards.
I recall needing to order the brackets in addition to the boards; however, it appears as though some suppliers are now bundling these together as a package.
Here is the link to the Dee Zee product page:
NXc Running Boards
A quick google search reveals you may be able to get them for less than $350 with free shipping. In any case, I would verify the brackets are included though. Here is one option (use coupon code NEWBIE for 10% off):
Auto Accessories Dee Zee Page
Good luck.
John
The Dee Zee running boards are probably the best ones in terms of functionality and looks. I have the OEM running boards and if I knew that Dee Zee made these, I would have bought them instead of the OEM. Like jrhart said, the OEM ones really don't provide much space for your feet. You might be able to get about 3-3.5 inches on there and thats about it. Even after adjusting the OEM boards and moving them out there isn't much space for your feet.
If you plan on doing any off roading or anything else remotely dangerous, you might want to look at sliders. Budbuilt has really nice bump out sliders. They are about $450 if I recall and you'll have a dual purpose for them. I'm not sure if you need to modify your rocker panels to fit these though. Other companies offer there own versions of sliders, like Shrockworks (and I'm drawing blanks on other companies).
NXc Running Boards
Good luck.
John
These fit no mod? I have Limited as well and not many good options w/o needing mod. I hate my OEM's, took them off. CAN you please post a pic, I might have to get these if look good. I would go black trim/stainless. Thanks!
what OEM running boards are you guys saying has no toe space? I can fit half of my foot on mine... I do like those DEEZEE boards though. Anyone got a pic on their truck?
My OEM running boards look like these....http://www.toyota-4runner.org/1047325-post9.html Stole the picture from another thread. These are not automatic and are the ones that were from SouthEast regions I think. Different regions might of had different running board styles, if I recall correctly.
Dee Zee NXC pictures from this thread. http://www.toyota-4runner.org/5th-gen-t4rs/106114-dee-zee-nxc-running-boards-limited.html
more links for y'all
http://www.toyota-4runner.org/5th-gen-t4rs/87565-running-board-question-finally-solved.html
http://www.toyota-4runner.org/5th-gen-t4rs/102990-looking-aftermarket-running-boards.html
http://www.toyota-4runner.org/5th-gen-t4rs/79049-deezee-running-boards-installed-limited.html
One guy took his cause chrome yellowed. I am thinking black trim/stainless steel step is the best combo option. They look great!
Got pics of yours?
Thanks for the info everyone! Seems like everyone likes the DeeZee ones. I will look into those. I didnt like the OEM ones because they look huge and makes the car look lower. But thats just my opinion.
those are the same OWEM boards I have... I think there is more than enough foot space. I have a size 10 shoe so not huge but more than enough to get in and out.... the deezee looks cool but too big a gap between the rocker and the board for my liking.
Side note: the 2012 OEM running boards aren't as clunky as ours.... Just gotta find the pic
Says private photo album. Please enter private password. If you hover mouse over pic, then left click on "IMG link, it will copy it, then paste link here. That's how to post photos here the easiest if you do not mind.
Thanks for the help...hope this one works:
DSC03156.jpg~original
John
X2 on the DeeZee boards. Good solid board, all aluminum, rubber treads for good grip, no flex, heavy steel brackets. Highly recommend them!
Easy to install? did you need to fab anything or was it a straight forward screw and bolt job?
Bolt on install 6 bolts per side and was very easy. Took about 30 minutes total and that was lying on my back in the driveway. Only tools need were 3/8 ratchet 3" extension and 12 or 13 mm socket (forget the actual size :shrug:).
Sounds good to me, time to place my order.
