alignment spec for minimal fender rub
swansong04
so ,
the fed ex guy came the other day with a few boxes full of goodies and next weekend i am going to get my new lift installed .
here is what i ordered
toytec ultimate lift
LR uca's
1.25 "apidertraxx spacer
i am retaining my stock 20" limited wheels for now and going with 275/60/20 nitto t/g's
now my question is when i take it to the alignment shop i would assume they would know all the alignment specs. but! if they don't what should i tell them to get the best maximum clearannce to minimize inner fender rub ..?
thanks for any info
so ,
LR uca's
thanks for any info
More pos. caster,like 4.0 or more but set the LR's to Zero and do the fender liner mod! Spidertrax increase the chance of rubbing though.
http://www.toyota-4runner.org/5th-gen-t4rs/115173-lift-installed-alignment-help-please.html
really?? i did not know that . i thought they were supposed to help with the rubbing . i assume then they are strictly for the stance then . ?
thanks for the great info . whoa! i have a lot to learn .
GARY
GARY
Ya you may want to rethink the use of spacers but if you already have them I guess you could try it both ways. As for the alignment Harper is the man! Follow his advise and you'll be fine, as you'll see in the attached thread I know from experience.
Good luck and don't forget the pic's :thumb3:
thanks for the comments . yea , when it comes to the spacers i was following UFG8R Runner's build and i just emulated his so i went with the same spacers .
also this is my wife's 4runner and it will not see much off road if any so i assume the rub will be minimal unless at full lock ?
Was he having any rub issues? I've seen his build but forget if he did. I'm thinking that with ~3" lift, no spacers and ~ +4 caster you won't have any problems. With spacers :shrug: guess we'll see eh.
