Nav System Updating
You can just make the jump directly to the latest version, no need to get everything in between. Also, you nav generation never changes. If your nav is Gen6 (2010 4Runner), then you always stay with that generations update which in your case will always be released on disc. My chart simply details what Gen each model year nav system is.
Definitely not worth it to get the disc at the link you provided. There are great places to obtain much cheaper and more reliable too.
Awesome great info!
Where do you recommend one purchase the newest most up to date NAV disc?
How did it go??
well, i am GLAD you asked!!!
it went perfectly. paid. shipped swiftly. received without issue. the owners manual for the navigation tells you how to pop out the old disc and put in a new one. did it. updated the maps!
if you are an impatient person don't freak out when your screen goes black and it flashes disc not found for about 5-10seconds. its just trying to read the disc. Then it reads it and updates. and you are in a time machine jolting you forward into the most recent (or close to it) navigation maps! :zoom:
I would buy from [MENTION=15785]J.A.[/MENTION] again in a heartbeat (and probably will in the next few years when my nav maps are out of date again :cheers: ). it was quick, easy, and it worked out. Now i can see roads that were constructed in the last 5 years haha, my disc was the original one that came in my truck.
I hope they will make graphics updates available at some point. I think the graphics on my nav look like an Atari 2600 compared to my BMW nav.
Hi forum team,
Last week I purchased the latest Entune map update #U-97D DVD from J.A. (Top 4Runners)... There's some installation information in the (Navigation & Audio system) manual but I think they're pertaining to the JBL Premium head unit; mine doesn't have an INFO or a MAP DATA button to use as instructed. I asked J.A. about that and if there were any further, more relevant instructions for those with the NON JBL headunits e.g., Xm HD)) Radio systems, but he wasn't aware of any.
BTW: J.A. and his website were Extremely conscientious and helpful with the initial transaction and even now are working to help out in any way possible... thank's [MENTION=15785]J.A.[/MENTION] Below is a picture of my hu. Does anyone know if it's map media format is on a DVD or microSD-card and how to access it? I really appreciate your help with this, Rgds!
20150430_174917.jpg~original
Hi forum team,
BTW: J.A. and his website were Extremely conscientious and helpful with the initial transaction and even now are working to help out in any way possible... thank's J.A.! Below is a picture of my hu. Does anyone know if it's map media format is on a DVD or microSD-card and how to access it? I really appreciate your help with this, Rgds!
I have asked the same as I want to update my 2012 Entune Navigation. Please keep us updated once you receive your dvd. Thanks!
I have the dvd, just don't know how to install it; or if I was supposed to order the SD-card instead :noidea: ...I'll be sure to post here again once I find out how to do it!
Starting with the 2012 model year, all the headunits from then are updated via the USB drive.
The file should be "01032-HBEKR-15A.zip" (before it's unpacked), that will update the Entune to 5.1.0
Unfortunately, it does not update the map and GraceNote databases; this is strictly for the Entune OS. As far as I know if you want to update the Map & GraceNote Databases you have to purchase an ACN (Activation Card Number) from the dealer parts department:
Then the technician will use a SST USB Drive to get a request code from the Headunit, then inputs the Request Code, the ACN and additional information into TIS for a valid software license key, which then gets inputted into the headunit and allows it to update the map databases via the SST USB. It takes something like 35mins just for the update to installation once you validate it.
I don't think they started using the MicroSD cards until about 2014 on a lot of our models. But it does seem to be plug & play.
As you can imagine Kayla, this is all very confusing; many conflicting posts! [MENTION=953]moneypit[/MENTION] says:
"The SD slot is behind on the bottom right below the seek button. It just pops open."
What does he mean when he says: "The SD slot is behind on the bottom" ...does he mean, 'behind the hu on the rear panel'... behind the front trim panel... Do We still need to have the dealerships update our navigation systems even though we can download the Entune O.S. updates ourselves (for free)? Have we accomplished anything, purchasing the 'Discs' and 'microSD-cards' ourselves only to learn that it still cannot be done... these questions are completely rhetorical; no answers required!! ...Just thinking...
Cheers
Cheers
All the Entune Headunits that have a Micro SD Card Slot for Navigation Data will have stampings on the cover for them. (We started integrating them in 2014+ models if I remember right, prior units from 2012~2014 used ACNs like I outlined above)
i.e. (Bottom Right Hand Corner of this Entune unit)
These units require the SD Card to be updated, We haven't had any customers purchase new SD Cards for their 2014~2016 model vehicles that use these type of Navigation Data storage yet, but from having to replace a missing one in a 2016 it seems it may be plug and play.
The Entune OS updates are separate from the Navigation & GraceNote data. The USB Updates are for the headunit OS only, and the Discs will only update 2011 or older units I believe because they went to ACN for the 2012~2014 models.
mystery solved! :thumb3:
entune units are not as simple to update the maps as the old school atari head units that take compact discs. :madgrin:
2013 Limited with Gen 6 nav disc
Alright I don't know if this has been covered but I am just going to put it here anyways. According to JA's website my 2013 is Gen 7 (uses micro SD card) 12.1. However, I don't have a slot for a microSD anywhere. So, I think it is safe for me to say that my truck is an exception on JA's website as it is not Entune and is part of the JBL package. Also, my 2013 currently has a map DVD inserted version 12.1.
I am about to buy the latest Gen 6 disc off of JA's website but I wanted to be certain that I am purchasing the correct disc.
It should be noted that I have a Limited edition from Canada, if that makes any difference.
Also please don't roast me too hard for the crappy cell phone pics below, i have dropped my phone too many times that i have ruined the lens.
