20" LE rims with oversized Tires; Any concerns??
Does anyone have any pics of the 275/55s mounted?
Hi Ratt1,
I snapped these today with the ole' Android phone; hope they help. Installed them 2 weeks ago, couldn't be any more satisfied with their performance!!!
These are 275/55/R20, mounted on O.E. Limited rims-definitly no problems here!!
I have seen several post that the Limited is a 7 inch wheel and wanted to post the specs directly from Toyota.. The Limited does have a 7.5 inch wheel and the SRS has the 7 inch.
Thought this would help with so many threads going back and forth.. This opens up many more tire options.. Getting the Michelin 275 55 20 today. View attachment 75682
Have you not read the posts? Rigtec measured his LE wheel: SEVEN INCHES. Toyota spec sheet is wrong. Read your wheel stamping and door jamb plate. Don't start a rumor again. You guys can't "hope" your rims to 7 1/2 inches.
I have read every post possible for the last 2 weeks.... Never saw where the Toyota spec sheet was incorrect... Local Toyota dealer gave me 7.5 on Limited as well... Really don't care either way.. I am just wanting the right information from Toyota.. My post was with good intentions hoping to help or at least get the right answer.
The screen shot in his post shows 7.5J.. What am I missing.. Thought I have read every post and want this to go away as well..
Thanks
Thanks
http://www.toyota-4runner.org/5th-gen-t4rs/128142-toyota-rim-size-numbers-misleading-3.html
Read the last several posts of the link. Everyone was arguing on what width was correct and Greg went and has his spare dismounted. He measured and posted pics.
Thanks
The LE rim measures 7" across the bead, this is the CORRECT regulatory method of rim measurement. Further, all LE door tags show 20x7J (J is the shape of the lip)
There is a clear conflict with Toyotas marketing specs and regulatory specs, so, either Toyota is fudging the number for marketing purposes or they are not following the globally accepted standard rim measurement regulations or the rim was initially to be 7.5 and marketing never caught the change to 7".
I would like to see an actual measurement of the SR5 rim, if bead to bead it is also 7" then Toyota is using 2 different standards for the same vehicle.
There is a regulatory requirement for the technical spec of 7 as it is on the door tag but generally marketing specs have a wide interpretation of terms like "width".
ok, this is getting interesting, I received a response from Toyota and they claimed that it is 20 x 7J and linked to the owners manual.
So, I tried to respond with the link to the Toyota spec doc that showed 7.5 x 20 and the page was "NOT FOUND".. GONE
About Toyota | Our News | 2013 Toyota 4Runner Product Information
HOWEVER, I did find that doc on another Toyota page, so I sent the link and the document to them and asked for clarification on the discrepancy...
Are there any other sources of the 7.5 spec from Toyota, unfortunately most or all of the third party sites have published the 7.5 spec and tire/wheel vendors have used 7.5
So, it is 20x7 but where did the 7.5 come from this error goes back to 2010...
a link for the 2010 spec from Toyota also stated 7.5
http://pressroom.toyota.com/article_download.cfm?article_id=2635
Probably a proofreader or editor overlooked it. It's no big deal because the doorjam + the wheel stamp has the correct rim width. Are you gonna go by a sales spec sheet or a casting stamp?
So glad that we (most of us), have FINALLY come to a reasonable understanding of the truth on this subject.
However, before some Genius starts to develop a theory (and I can feel it coming), that somehow, the spare tire that I measured for this discussion, is "Different", than the rims that Toyota casts, to be installed and driven on...I'm way ahead of you.
After my spare was dismounted and measured, I decided to measure the thickness of the rim flanges (outside of the bead surfaces), and the distance between flange to flange, with a wheel caliper; allows you to measure the outer width of the rim, without dismounting the tire.
And I'm very happy to report, that the rim that Toyota intended to be used for the spare tire, was cast "EXACTLY" the same as all of the other standard 20" rims. NOT DIFFERENT!!! :reddance:
rigtec, Best regards
Hey guys, I emailed the seller on ebay who is selling those Limited replica wheels and this is the responce I got from him.. Is he right or just telling me what I want too here so he can make a sale?
Link to auction
20 Toyota 4Runner FJ Cruiser Tacoma for 2010 2011 2012 Alloy Wheels Rims | eBay
Me - Hi, I am interested in these wheels but how come the offset is so high at +30? The oem limited wheels the offset is -12 I believe.
Seller - Hi,
These wheels are 20 x 8.5 and the OEM are 20 x 7, the low offset in the OEM is needed to compensate such a narrow wheel, that really needs to stick out in order to look normal in a 4Runner. Since the wheels we are selling are wider, a higher offset is required. The perfect fitment is a combination of the width and offset of the wheel. These wheels are guaranteed to perfectly fit the vehicles listed on the fitment chart or you money back.
Thanks and regards,
Me - Hi. Will the wheels you are selling guaranteed too sit flush with the wheel well? Since its such a high offset it won't rub in the back of the wheels?
Seller- Hi, These wheels will perfectly fit your SUV without the need of spacers, will not stick out and will not rub in the back of the wheels.
These wheels will sit flush with the wheels well, guaranteed or your money back.
Thanks,
Link to auction
Seller - Hi,
Thanks and regards,
Thanks,
He is correct, the outside of the replica 20x8.5 will sit about the same as the OEM 20x7, because of the offset change. Most of the gain is on the inside.
The issue is putting on a 275 or 285 tire puts nearly all the gain of width on the inside, I don't know how much room is there to accommodate this, there may be enough room. however for looks and stance I would prefer slightly more on the outside. So, it depends on the tire you want to run..
on the 20x8.5,
a 275 tire will be about 1.2" closer on the inside..
a 285 tire will be about 1.4" closer on the inside..
So, I don't know if a spacer is necessary but it would be ideal to move everything out a bit. For example when you stuff a 275 on an OEM 7" rim, you get about 0.6" added on each side.
I wonder if the vendor would sell them is sets of 5 ???
Maybe somebody can chime in on how much room is available on the inside to accommodate a wider tire.
