TE - Rigid Install in the Rear Bumper
Titanpat57
Howdy,
Had the opportunity to pick up a set of these from Bobby at High Tech, nice product, nice price, awesome customer service (although we know that's not news)
The lights.... SR-M Flush Mount Diffused
I'm very happy with the light spread and the look. I thought about putting them in the rear hatch, but then it would only throw light when the gate was down...no good...so this was the next logical spot on the Trail Edition
One thing I will say, is I used a Rotozip tool (designed for cutting sheetrock) and it worked quite well...I have a cordless model. I cut through the first section of plastic, then the one behind it using the supplied template. I installed two pieces of 3M 2" wide blue tape to protect the plastic from scratching and such.
When it came time to mount the lights themselves, I had some cabinet door bumpers, self stick, that I used on the bottom flange of the light, which tipped the light more upright, and increase the spread behind the truck. I feel if they were not shimmed up, they would shoot down to far, not taking advantage of the light's potential.
The switch supplied with the lights worked well, I happened to find a rectangular plastic plug, with a little black silicone, that slide right in, and looked acceptable.
Wiring was pretty basic, the usual route through the door sills, to the Blue Sea box under the hood. The only pain was drilling up near the turnsignal to feed the wire to the rear...a little hairy for a backyard mechanic like me.
Once the wiring was set, I taped around the lights with 3/4" wide blue tape, and black silicone caulked around the lights themselves. In the morning, when the caulking set, I gave the screws a quarter turn to make sure they were tight. On a side note, I tried tightening the lights down prior to caulking, and found that the screws actually squeezed the rubber bumpers out...so I back them out just enough to hold them straight.
IMG_20121113_113310.jpg~original
IMG_20121113_113322.jpg~original
IMG_20121113_113325.jpg~original
and gratuitous "lights on in the f'in daylight, which serves no practical purpose" shot...
IMG_20121113_113344.jpg~original
and the switch...I know, the trucks filthy...cut a brother some slack, we just had a hurricane..
IMG_20121113_113354.jpg~original
oh...
and the cat got high centered on the cellar steps...tried to winch his a$$ off...but I ended up finally using Pounce..
IMG_20121111_171330.jpg~original
Nice job, but be careful if you wheel it. That rear bumper trim piece has been sitting in the back of my truck for a couple weeks after being forcibly removed by an obstacle.
great point....
I checked...and there's not really anything high enough at the Mall that'll hit em'....except maybe backing into a light bollard...
Yeah, that piece has the "Duct tape mod" on mine thanks to the peer pressure of Harper7, Limamike, and 4Shorerunner...
Looks good.
I was just out today test fitting a Diffused and Flood pattern SR-M lights. My plan was to mount one diffused and one flood on the rear roof rack. I tested them out last night and I think I like the flood on the rear more and diffused for the sides. The upside down mounting position I ended up with for the rear is a compromise, but the lights are protected by the rack and out of the way.
Here is a link to the photos I took.
http://rhino4runnersuspension.shutterfly.com/pictures/1027
I like this much better than your first attempt!
Aint the innernet wunderful?:)
Thanks guys..
bite me Jeff!:dammit:
those were my first (I think anywhere) homemade back up LED lights...and they actually worked!!
I must do this mod. I should have removed my OLD glass/alum LEDs before I traded in my truck :redbrick:
ac99dc92e1334e4a179c825a81b03086.jpg~original
IMG_4211_zpsfab10539.jpg~original
