level
I'm afraid you're going to get differing opinions on .85 and 1.75. Here's mine set on .85. I never took any measurements.
Don't forget you should reaim your headlights.
You will most certainly see a lot of opinions...so I figured I would weigh in. I think I have read threads and looked at pictures of almost every Bilstein build on this forum in others. Based on what I have seen and read...all vehicles being different of course....the .85 setting is the best bet w/ no rear lift. Looks to me that the .85 setting leaves most with a tiiiiiny rake left, but the 1.75 setting will most likely leave you with reverse rake. Again, all vehicles are different (even 4runner to 4runner). You will love the Bilsteins....good luck!
Another thing to consider is how much you plan to load up the rear. If you do plan to carry lots of stuff, you might want to keep some rake so it doesn't look too nose high while the rear is sagging down with the extra weight. My vote goes to 0.85" :)
As per philsey & FatTiresRollin 0.85 seems to be where it's at. I've searched to the end of this forum and back and IMO this is where you you want to be. 1.75 looks great with a little rear lift, but w/o you may get the reverse rake which you definitely don't want. Check out sporty87's T4R in the link below.
Level only, no lift?
