17" TRD wheels
Falls
Super Moderator
I want to possibly put some on the 4R .
Anyone have any pics of what they look like on their 5th gen. My truck is silver TE , I plan to stay with stock tire size but go more aggressive and a 2.5/1.5 Daystar spacer lift.
Do these wheels have a different width and offset than my factory wheels ??
Does anyone have specs on factory TE rims ?
Thank you
Mike
I found these pictures on the forums this morning cuz I was interested as well.
17' TRD Forged Wheel with BeadLock Ring (PTR45-35010)
TRD 17 inch x 7.5 inch x 6 mm FORGED Aluminum Off-Road Wheel with Bead Lock Styling. 6 on 139.7mm P.C.D. 106 mm Center Bore.
Uses 12mm TRD Spline-Drive Conical-Seat Lug Nut Kit (PTR27-89100) included for PPO, recommended and sold separately for DIO.
Tires are OE P265/70R17 113S M + S This wheel is conflicted with the Limited models with 20 inch OE wheels due to 20 inch door jamb tire pressure label.
PPO Code: L2 PPO Time: 1.63 hrs TRD wheel "LONG" lugnut installation kit, PTR27-89100 is included for PPO (required and sold separately for DIO).
This kit comes with 20 Spline-Drive Conical-Seat 12mm Lug Nuts with captured conical swivel washers, 1 "LONG" Spline Drive Tool, 4 TRD Wheel Locks with TRD logo laser-etched on top of each Lock, and 1 TRD "LONG" Wheel Lock Tool. 21mm wrench flat.
All TRD Wheels are designed for use with 20 degree OE wheel sensors and fit kits. 20 degree sensors are already on OE Alloy wheels.
Refer to your parts department and or the installation instructions for proper TPMS part number required for your particular application.
Backed by Toyota's 3-year/36,000-mile New Vehicle Limited Warranty, valid at any Toyota dealership nationwide.
[per http://www.toyotatrdparts.com/scripts/prodView.asp?idproduct=-118]
Okki
The only thing I haven't really seen except for one blurb in one of the linked threads is the actual weight of the TRD wheels vs. the OEM Trail wheels. From reading the other threads it appears that the TRD wheels weight about as much as the OEM Trail wheels.
If anyone has actual weights that would be great.
I don't recall the actual weight numbers but I did weigh both wheels with my Feedback Sports digital scale (mostly for weighing biking & other camping gear) and it was a wash -- less than a pound different as I recall (and I'm thinking it was less than a 1/2 lb). I may have the numbers hiding in the garage on some scratch paper and I'll post the numbers if I come across 'em...
Thanks, it was your thread I believe I was referring to. Kinda sucks that there is no significant weight difference.
Thanks all of you guys . I showed them to the wife and she does not like them and wants me to get black wheels , gotta love it. :)
make sure you wear your skirt and make her a samich before you buy black wheels:hiding:
