OTRATTW Switches Center Console
Romanred62
I know. I know. "Use the search bar..." Well I've tried for about an hour now with no luck.
I found a thread one day where someone had mounted 6 OTRATTW switches in the little useless area just in front of the gear shifter on the center console. I should have saved the thread since it's how I want to install my switches there as well. Does anyone happen to have this thread saved? (Like I should've done.) :help:
[MENTION=78705]jangoforhire[/MENTION]
AKA "Switch-b i t ch"! :whip::thumb::hello:
If it has a switch.. needs a switch .....or could use 2 or 3 more switches... He's your guy.
Okki
Okki
Actually, I believe it is well known that the switches gets him the b-itches; and not that he's a switch b-itch, lol.
OP I replied to your PM. Let me know if you have any other questions!
For everyone else, "Want to come see the 19 switches in my truck" currently has a 23% success rate. And if that one fails, I always default to: "Hey babe, want to come check out my machined aluminum billet upper control arms?". Works like a charm*
*disclaimer: I never have, nor never will actually try any of these (unless for a bet)
As one of the 23% I now feel cheap and used by not holding out to see the machined aluminum billet upper control arms. :naughty:
Damn Jango- even Snoop only had 16 switches...
Was this what you were referring to?
http://www.toyota-4runner.org/5th-gen-t4rs/146750-warnerd9s-build-thread.html
