06-06-2015, 02:04 PM
#46
Originally Posted by 4Funnr
I have yet to receive my equipment to begin trying to wire this all up. Why would one need both harnesses?
I can see the benefit of having the LED bar switch off when HIGH beams are switched off but I would like to wire mine independently. Would I still need both of these Slee harnesses?
Using both harnesses would allow for a simple plug and play setup where the light bar would be controlled by the highbeams (only on when they are on) which is great for on road driving.
If you want the light bar to work independently you could still use the Slee harness but you would probably need to change the pins in the relay connector to be switched only by the switch with no input from the headlights. At that point you're probably better off building your own custom harness.
2010 4Runner Trail Edition
06-12-2015, 09:22 PM
#47
Can somebody please explain to me how to wire up an AoB knockout switch to low beams with a 20" Rigid LED bar? And feel free to walk me through it as if I've never had an electrical engineering class.
Not finding a walk through with this combination on the site but we know how well the search engine works.
1st 2010 4R Magnetic Gray Trail on the Forum
06-12-2015, 09:39 PM
#48
Real Name: Halko
Real Name: Halko
I'm not much help, but I wired my SR20 straight off the battery and used the AOB instructions to wire straight to the rigid harness. With the 20 it should have the relay built into wiring harness so if you skip splicing into factory wiring you could have it done in about 20 mins. Yes it's better to do it other ways but it's easy and great for me.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
06-12-2015, 10:00 PM
#49
Thanks for the feedback!
If you do it your way the AoB knockout switch won't illuminate or dim with headlights though will it? Also won't make sure the light bar goes off when your low beams go off.
06-12-2015, 10:08 PM
#50
Real Name: Halko
Real Name: Halko
The upper led in switch does light up when activated, to turn bottom led on with lights you need to tap one more wire (either way you wire it you have to do this to get it to light on with stock lights). Mine is purely manual so regardless of everything else, including whether truck is on or not, the switch runs the light bar. Since I never use mine unless off-road it doesn't matter to me.
Build link:
06-13-2015, 12:50 AM
#51
So here is my best guess with no harnesses and just chopping wires willy nilly.
Black from RI LED goes to black from AoB switch.
Blue from RI LED goes to red from AoB switch.
Red from RI LED goes to blue from AoB switch.
Something random in the dash goes to green from AoB switch.
Hope this is correct.
06-13-2015, 09:06 AM
#52
Real Name: Halko
Real Name: Halko
The key is to get the ground right, from what I recall that sounds right as I vaguely remember that the colors didn't match up. Once the ground is attached and you hook up the others it's obvious. On the green wire, search around this site, I don't remember which wire folks tapped to get the lower led to turn on with dash lights but it's written up (I think it's the RSCA, but don't quote me on that) make sure you test with a meter. I think there is more info on dimming in
@ CSix
build thread. The AOB should have had instructions to help.
I never connected the green wire myself, currently all my rigid lights are independent of factory wiring, at some point I will change it but other than the risk of leaving them on and running down my battery it works fine.
Build link:
06-13-2015, 12:12 PM
#53
Real Name: 3 guesses..........
Here's the schematic AOB provided for wiring......
If you want switch light to dim with dash lights, refer to post #37. Dimming function is through the ground wire, so black wire from switch would connect to gray wire (-) at factory harness. Blue wire from switch would connect to green wire (+) at factory harness per attached diagram.
Always test wires with a volt meter for proper operation prior to making any connection!
Edit: Forgot to mention, these switches can only handle a 3 amp load, it is highly recommended to use a relay when interfacing with aux lighting.
'12 SR5, Blizzard Pearl * Factory (style) Fog Light Switch-Fits knock-out! * 30" BD Stealth LED Light Bar, Upper Grill '12 SR5 * Reverse Light Mod-SR5 Factory Bumper * FN f(x) Pro Wheels - Custom Coating * LLumar Paint Protection/Tint, Flowmaster Cat-Back, Bilstein 6112/5160, LR UCA's, AirLift w/Load Control, 285/70/17 Nitto TG, LW's D2S 4.0 HID low beam mod, V-LED Interior/Reverse/LMZ High Beam/Turn Signals/V-6 DRL Lights (all 5000K), Kappa Dash/Doors/Hatch Speakers, CompuStar Remote Start, B&M Trans Cooler, Devil Horn Emblems, XB LED Fogs, Dongle Mod, TRD CAI, DC 270-XP Alt
06-13-2015, 03:40 PM
#54
Real Name: Halko
Real Name: Halko
Almost all rigid wiring harness have the relay built in along with the proper fuse, they make it mostly dummy proof.
Only the super low amp dually's etc don't have the relay in the harness.
Build link:
06-13-2015, 05:16 PM
#55
It looks like the Rigid has a relay built in but I don't know if it drops all the way down to 3 amps.
I don't really understand what is supposed to tap into what to get the LED light bar to shut off when the headlights are shut off.
06-13-2015, 08:28 PM
#56
Real Name: Halko
Real Name: Halko
You shouldn't have to worry about amps with the relay, that takes care of the switch limits.
You'll have to wire it differently than the rigid instructions and tap into truck wiring under the hood for that. Someone that knows more than me would have to explain it, when in doubt start with Okki's build thread. But hopefully you would understand his schematics better than me.
Build link:
06-13-2015, 11:33 PM
#57
Real Name: Greg
Real Name: Greg
I'll suggest this if some have reservations about tying into the head-light circuit wiring.
A good alternative to using the headlight circuit as 'a trigger' (power supply) can be the 12v Courtesy power outlet e.g., cigarette lighter, 12v accessory charger. What makes this a good choice is that the circuit shuts-off when the truck shuts off; so no chance of leaving your auxiliary lighting on when you park the truck. ...The Light Green wire is HOT, Blk/Wht wire is Gnd.
NOTICE: This Blk/Wht ground wire (mentioned above) will not provide illumination circuit dimming (Dimmer dial); that must be obtained from the 'Courtesy illumination' circuit from one of the other accessories that are on that circuit e.g., RSCA, Temp controls, wiper/side-view mirror heater, Seat heater dials... etc!
Rgds
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
06-14-2015, 06:40 PM
#58
Thanks for all your help so far. I think I may be getting there. Just a couple more questions.
The Rigid harness kit has three wires that attach easily to a three-pronged switch. they are labeled this way:
Black wire to gold prong (Switch ground)
Blue wire to middle prong (Switch output)
Red wire to remaining prong (Switch power)
But the AoB switch has four wires and to supply dimmable backlighting with Ignition-ON I believe it needs to be wired this way:
Black wire from AoB switch goes to Gray wire at factory harness.
Blue wire from AoB switch goes to Green wire at factory harness.
Red wire from AoB switch goes to Blue wire at Rigid harness.
Green wire from AoB switch goes to Red wire at Rigid harness.
So, what do I do withe the extra unused Black wire at the Rigid harness?
Does it not need to be used because it is the AoB switch Ground and I've already grounded the switch via the Gray wire at factory harness?
Second question is, how are you tapping into the wire from the RSCA switch? There isn't much wire to play with here. I'm a bit worried about stripping it and wiring two leads from it to reconnect it all with the new swtich.
06-14-2015, 06:58 PM
#59
Real Name: Greg
Real Name: Greg
Hi 4funnr,
The Ridged switch with three prongs doesn't have the capability of accommodating the courtesy lighting Dimmer feature as does the A.O.B. switch. The 'Ridged' switch has (1) 12V power in, (2) Gnd; for the on indicator light circuit, and (3) power out; to trigger the relay(s). The A.O.B. switch has the fourth pin for utilizing the courtesy light dimmer dial. Rgds!
EDIT: There shouldn't be any unused wires on the 'Ridged' harness e.g., RED 12V power input (Battery), Blk Earth Gnd (NEG Battery), and Blue, switch output power (trigger) to relay; according to your list.
06-14-2015, 08:18 PM
#60
Originally Posted by rigtec
Hi 4funnr,
But if I'm tapping into the Factory ground for the dimming capability, then the Rigid ground isn't needed, right? Or should I wire them together and then in?
