MV-50 onboard compressor install
CrazyNorwegian
MV-50 onboard compressor install(images fixed)
First off i would like to thank [MENTION=65614]Antman[/MENTION] for his original writeup. As you all know the importance of airing down/airing back up after hitting the trails, an on-board compressor was at the top of my first mod list. I didn't want anything super expensive since it will only be used occasionally, and I have no need to power air tools. So I went for what seems the most favorable and reliable budget compressor in the off-road world (MV-50). Out of the box it was quite impressive for the price. So I used the info on antman's build page as a guideline to get it on board. The problem is the leg/stand on the MV-50 isn't wide enough to to bolt onto the available studs in the engine bay. I tried to widen the holes on the stand for the MV-50 but I felt the remaining metal holding the compressor to the studs wouldn't be sufficient. So this is what I did.
(from the passenger side fender) the 2 mounting studs are seen, I also sanded down the threaded empty screw hole to relocate the maf ground and compressor ground. the screw hole was filled with junk in this photo but its there. (the darker silver area)
I raided home depot and bought a couple short nuts and bolts, and a nice ridged metal plate i found in the hardware section. The plate was a little over sized but it worked no problem. I drilled 2 holes to mount on the studs and 2 more to mount the bracket i un-screwed from the bottom of the compressor.
Added a couple thick rubber and metal washers to the studs to absorb some of the vibration.
All mounted up
Thankfully it went in like a glove with about 2/3" clearance from the firewall. It feels very solid and does not vibrate at all during operation. I hard wired everything in and cleaned up all the wires and its been great so far. I spent a little over $60 for the compressor and about $10 in parts for the install.
same compressor i have! i've thought about mounting it under there, but meh.. i'll just pull it out every time i need it
:spy:
Not sure if i'm allowed over here, but I did this too and mated it with a 1 gallon tank. You can't beat the mv50 for the price
http://www.toyota-4runner.org/4th-gen-t4rs/148216-board-air-cheap-4.html
Ignore my ignorance in that thread, it was my first time really working with an air compressor at all :eek:
I might do that down the road once I run out of other things to do. The tank probably won't help much with tire inflation, but down the road after I get a rear air locker, train horn, and front mounted potato launcher it will be a must.
I mounted it because I really didn't want to always keep it in the back, and I like to keep things clutter free.
Ditto. I wasn't even gonna do a tank at first, but i figured hey why not, it was only an extra 50 bucks or so to add and it's got some bling factor. Plus I can use cool things like blow guns to clean out my truck
Come on man. No interior switches? I can think of at least 2 switches you could hook up for that!! Haha compressor looks great!
Why wouldn't a tank be helpful for airing tires?
The tank will be empty before you are done with the first tire. A small mountable tank doesn't hold much psi. Some people use a portable co2 tank to fill their tires, but those tanks hold much higher pressure, and can't be filled with a regular compressor.
I did the same thing with my Vair compressor. I did use the "T" shaped Simpson strong ties (X2) because they gave me even more support. I still have to clip the hot line to my second battery but I am happy with the results. I also have my 50' air line and gauge right behind the headlight.
How is the fill time per tire with the MV50 like from 15 to 35 or 20 to 35 ??
It will vary widely, depending on the MV50, anywhere from 2 minutes, to infinite. They are a very poorly made knock-off of the Viair 400, and the first, and only QC check seems to be the purchaser.
I have had several that ranged from DOA, to worked once, to worked several times, before breaking, or performance diminishing to unusable levels.
