Oil filter change no skidplate removal required
ron in sc
Completed oil and filter change and found that I only need to remove 4 bolt to gain access to oil filter.
One photo taken from under vehicle looking toward the front of vehicle. Yellow arrow points towards front of vehicle. Red paint spots indicate the 4 bolts that need to be removed. After that the skidplate piviots forward toward the front of the vehicle like it's on a hinge or something.
The other photo has yellow arrow pointing at filter housing. There is plenty of room to get to and change filter.
Edited: Added another photo from the front you can see the assembly hanging down.
Sounds legit...
What year and model? My 2010 Trail doesn't look like that.
Mine is a 2012 SR5.
I have a front mounted hitch which obscures the view somewhat.
Mine has some kind of mesh going on in there.
If I want to remove the that plastic box and cover it comes out easily with I think it's four plastic pop type rivits.
I think our trail one is slightly different due to the KDSS...the dinky mesh guard sit's way further towards the front then the non-KDSS version it seems.
I do not think that would impede access or pivoting the skidplate
If anyone want some other photos please ask now while vehicle is still on lift.
Op, mine looks like this underneath. Which bolts did you remove?
Edit: I see them pointed out in red. Perhaps it is SR5 specific, but I will give this a try when I do my oil change next. Thanks!
[MENTION=81067]ron in sc[/MENTION] ,
When doing write-ups, which this one is informative, it would help tremendously if you have listed what year make model you have in your signature. This would help avoid any confusion.
oil changes
It seems like a lot of BS just to change oil on these ( I'm a DIY'r )
What are you all dropping oil at for first change? and there after?
I had a 04' and 07' and it was easy.
Is this a totally different motor?
Is it any better than others?
I really didn't do much research on this since the last 2 were perfect vehicles
Thanks in advance
You guys know he started this thread 3 years ago, right?:gossip:
Thanks in advance
uhhhhhhh. Yes.
Of course if they started a new thread some other guy would blast them for not searching and starting a new thread. Tough to win around here either way
^^ this
I don't get the "why are you talking about this again and you should have searched" trolls on here.
Some guys just like to talk about sh!t and if you don't want to be a part of that conversation walk away, or in a forum DON'T CLICK ON IT or just go back to your porn.
They're basically telling other people to STFU which they would NEVER do in person because of the obvious a$$ kicking they would receive.
