20x9 Wheel Help
mx355
I am looking at putting a set of 20x9" wheels on my 2013 SR5. I am leveled up front with .85 bilsteins. I am also running factory Mud Flaps front and rear and wish to keep them. Which set up would fit and work best. Thanks
Wheel Size Choices.
20X9 6-139.7 12MTB
Which is 5.47 BS)
20X9 6-139.7 -12MTB
(4.53 BS)
Tire Sizes.
275/55-20
285/50-20
Click the tire fitment guide in my signature and read the links. You should then be able to make this decision yourself.
there's more off-roaders here than Bling drivers, it may take longer to get a reply on 20's.. only a select few here have gone that route. that tire fitment guide is your best bet
Some of us just wanted a proper section width and sidewall look, so we kept the 20" wheels. Hell, I put 9" wide wheels on there with 275/55/20 tires and I have yet to throw a gang sign..
I know the 4Runner is great off road, I've taken this heap off road with my "bling" wheels. It did just fine. I don't spend every weekend rock crawling, then again I didn't buy the 4Runner to do that.
I used the fitment guide here, and didn't have an issue. I'd suggest you start there, find your wheels, and go to a tire shop. If the guy there can do more than fog a mirror, you should be able to get tires and wheels on your unit without rubbing so hard you think you are a Clinton white house intern.
Thanks for responses. I know the tire size I need to not rub and looked at fitment guide. I know most of you guys are off roaders and can afford to go trail a brand new vehicle, I just wasnt raised that way. I go off road but not anywhere extreme enough in a brand new vehicle to worry on wheel size.
My main question is with the 20x9. Will the 4.53 sit in or out more, or will the 5.47 sit more in or out? I do no want to rub on UCA or I do not want it to stick out way past fenders or rub fender flares.
I know the 17x7 sr5 has the 4.5 bs but will the 20x9 being wider need the 4.53, or 5.47 to represent similar results.
I have 20X9 -10 offset with about 4.5" back spacing and 275-55r20. Bilstein set to 2.5"... I rub and full turn on front fender liner. I had to remove small black trim to rear of wheel that covers the body mount just to rear of front wheels.
you might be fine with 50 Series profile. I am pretty sure that 5.5" back spacing it the most you can do. might be less than 1/8" between tire and uca with 5.5"BS
