my 2014 4runner Tint, thoughts and advice
roktoy
Some Facts about the Factory Tint in my 2014 4runner.
Front Windows:
Has natural green tint called solar green. Light meter at shop measured out at 80% light transmission.
Found some documentation online that said the factory is 77%
Rear Windows:
The rear windows do not have a film on them, its privacy glass with color dyed into the glass. Light meter at shop measured at 28%.
Same doc said the rears are 27.6% from the factory.
Here is a picture of the factory greenish tint in the stock windows.
WP_20140321_009_zps576042d8.jpg~original
1st time tinting:
The tint shop installed Suntek Carbon 25%, combined with the 80% Solar green factory tint yields 20% light transmission rate. Since I only did the front windows, it was slight darker looking out the front windows compared to the 28% rears. This was not too bad, but the Suntek brand tints have are charcoal colored tints, which means it got a greenish tone to them. This combined with the factory green yielded a green tone to the tint. It was noticeable in color from both the inside and outside of vehicle. I tried to see if it changed or evened out, but a month later I had to get this fixed. I called the tint shop and they were awesome and said to bring it in and they would change it out for me.
Here is a picture with my 1st tint, with only Suntek 25% in the fronts. You can see the green in the front windows. This is with the factory rear windows.
WP_20140215_001_zpsd1847f9a.jpg~original
2nd time Tinting:
So I went back to the tint shop and heard that Johnson Greystone was a good match along with 3M. The tint shop only had 3M CS, which is a smoke color, so it’s more of a blue grey color to it. We first tested the 35% film, which matched up perfectly in light transmission to the rears. Because 35% film with factory 80% yields 28% light transmission. With the 3M film the color match was much better. But you could still see green in the front windows and I’ve always thought the back windows at 28% was kind of light. So instead we did 3M CS 20%. Darker tint seems to hide the Green better, but you can never get rid of the green totally and match perfectly. But this film was pretty good. I also added Suntek 45% CXP to the rears. The Suntek as I have said before has a greenish color to it, I thought adding green to the rears would help it to match better.
So with the 3M CS 20 combined with the factory 80% front, yields 16% light transmission rate.
The rears with the Suntek 45, which is actually a 40% tint, combined with the factory 28% yields 11.2% light transmission in the rears.
Here is a color comparison of the 3 tints. As you can see the 3M is more bluish compared to the Suntek which has green in the film.
WP_20140323_004_zpsf6135715.jpg~original
From the outside with new tint. 3M CS 20 front, and Suntek 45 rears.
WP_20140321_013_zps9b871279.jpg~original
5319d581-1a88-4e46-bd07-86dd09b1357d_zps3e7af8a3.jpg~original
WP_20140321_017_zpsc2635b8d.jpg~original
Finally a picture from the inside looking out.
WP_20140321_004_zps21e9322e.jpg~original
Final Thoughts:
If you want to just do the front windows a 35% tint will match up best light transmission wise with the rears. Try a 3m or Johnson film. I also heard Sungard was pretty good too. Just have them show you the samples next to each other so you can compare, you can’t tell from the displays. You have to hold them up next to each other to compare color.
So with the 3M CS front and Suntek CXP rear tint, it looks really good. The Color match is much better. I can still see green in some light conditions, but since the tint is in the glass you can never get rid of it.
The darkness from the inside looking out is great, the front is slightly lighter. At night although things are darker, it’s still fine for nighttime driving.
Thanks a ton for the write-up, extremely valuable. I was just in the process of thinking through how to tint my fronts and this answered everything for me.
Truck looks awesome.
Great write up and your Runner looks great!
I just went through the same process. I wanted darker (in Florida) and I ended up going with front 5% and rear 15% (over factory). I measured the windows and have 5% front and 6% rear (but with the back window being tinted it appears darker).
Believe it or not this is actually less than my Tacoma I just traded (front 5%, rear .7% - Limo over factory). It was so bad I had to roll my windows down if there were no street lights around.
[/QUOTE]
Final Thoughts:
If you want to just do the front windows a 35% tint will match up best light transmission wise with the rears.....I also heard Sungard was pretty good too. [/QUOTE]
I just had my fronts done ~3weeks ago with Sungard at 35%. Turned out awesome, matches the factory tint color perfect and is slightly lighter than the rear windows which still looks good...so hopefully the fuzz here in VA wont bother me :flipoff:
I have 15% on front and 30% on the rears. Wish I would have done 15% over everything (not the windshield).
I went with 35% 3M on my fronts at the suggestion of my tint shop and am very pleased with the results.
Your truck looks great. In this State(MI) you are asking to be pulled over and having the tint removed. LEO want to be able to see who's driving!
I am originally from MI and know your pain. Its funny how in most other states the police have much better things to do then worry about window tint. The law here in VA is 50% on the front windows, I have 35% and have never had a issue.
Any suggestions for a 50% tint on the front? Don't want it too dark, in Commiefornia. I'm not looking to match the rear in darkness, but would like it to match in terms of color.
You will never be able to color match perfectly because of that darn stock green front windows. If you want match best from inside go with 35%, which will make you front light transmission rate at 28%. But from the outside it will look lighter in the front. A 30 or 25%, would be a better match from the outside. Here in Washington legal fronts are 25% tint, plus cops here don't seem bother people much about tint.
50% over the stock 80% will yield 40% in the fronts, pretty light, but legal in most states.
Best thing to do is go to a tint ship get some samples, take it home and compare them on your windows. Take your time, no hurry right.
Great write up and detailed post. Your truck looks great.
I must be weird, though, because I strangely like the factory green tint, and can't stand anything inhibiting night vision.
Maybe an old man thing.
good thread and thanks for posting. I have a 2015 Limited that I just picked up and I noticed looking out, a difference in the back and front tint. The installer said they noticed a "yellow" hue to the glass, and was only the second vehicle they did that had that type of OEM tint (front color differing from rear).
They did a 30% Llumar film. I'll see what it looks like when it stops raining later this week.
I did the front windshield and moon-roof too. Used Solar Guard 75, but 3M has Crystaline and there is a funny German name film too. It's too light to be noticed by the police and there is no problem with reflections or night vision. I added it to block the UV and heat and think it's really worth it.
Great writeup.
I just told my tint guy (great service if you are in the Denver area milehighwindowtint dot com) that I had a black 2015 Trail and wanted to match the front windows exactly to the rear. He did it perfectly.
