Originally Posted by Bimmer-Bob
I know some manufacturers specify two different maximum tongue weights for their vehicles - one for using a regular hitch, and a second (typically higher) value if using a weight-distributing hitch. So near as I can tell from digging into the T4R's owner's manual and Toyota's website, there is only one value provided: 500# (with no mention of hitch type).
I came across some info on Car and Driver's website stating that the max tongue weight when using a dead weight hitch is 470# (or 10% of the truck's 2014#max towing capacity). Interestingly, it also gives a value for max tongue weight with a WDH: 705#. Thing is, I have no idea where they got these numbers. Does anyone maybe have a newer revision of the 2014 OM that has this info?
As far as I've seen, Toyota has never published a tongue/trailer weight for the 5th Gen 4Runner when using a weight distributing hitch. So, you might assume it is the same as a weight carrying hitch. I call the 705# number bunk. WDHs are only mentioned in the 2012/2013 owner's manual. There is no WDH reference in the 2010, 2011, or 2014 manuals.
Otherwise, can anyone speak in general terms about how a WDH affects max tongue weight, if at all?
1engineer's link gives a good (probably the best on the internet) explanation of WDHs and their operation. If you want to burrow deep into the rabbit of of towing physics/dynamics, search for Ron Gratz on the rv.net forums.
The WDH transfers weight from the rear axle up to the front, lessening sag and increasing the
understeer gradient. I think the SAE towing standard requires a positive undsteer gradient at 0.3g steady cornering.
Adding airbags to the rear actually decreases the understeer gradient (drives the system towards oversteer). Not necessarily a bad thing if the system (tow vehicle + trailer) is still understeering after adding the bags.
Regarding system stability, you have two main components.
Is the trailer stable?
Is the system (tow vehicle + trailer) stable? [understeers at 0.3g]
Trailer stability is related to tongue weight and the trailer's polar moment of inertia [Ron Gratz has a nice thread explaining this]. Once you pass a minimum tongue weight % (SAE uses 10% in their towing standard, but it varies), the trailer is stable. However, adding more tongue weight decreases the understeer gradient of the tow vehicle + trailer system. So there you have to walk the line between having enough tongue weight for the trailer to be stable, but not too much to make the system unstable. This is really only an issue when you get near the tow limit. A 1500 lb trailer with a 25% tongue weight (375 lbs tongue weight) isn't going to make the 4Runner an oversteering death machine.
