2013 T4R engine ticking noise
Melvinper
Hi,
I have a 2013 4runner SR5 with 20,000miles. The engine has this ticking noise that sounds like a valve noise more noticable on the right side. I took it to the dealer and they told me that the noise is a normal noise for that engine. Does anybody knows about this? Is your 4runner also has that ticking engine noise.
Thanks for your help!
When you start it up and for about 5 minutes after? Sounds like valve clatter?
Sorry I don't know anything about it lol. J/K yes mine does it too. I really don't care if anyone elses does it as its no big deal to me.
Same here. I have been to two Toyota dealers and one independent Toyota shop and they all tell me it is perfectly normal for the 5th gens.
It is most likely the fuel injectors. They can be quite loud. Listen to any fuel injected engine and you will hear a clatter that sounds very similar to valve lash noise.
All 1GR-FE engines, be them single or dual VVTi seem to have this "Toyota Tick." Sources seem to range from VSC valves, rocker rollers, fuel injectors, ect. All I know is that these engines tick and are more noticeable with the window down at idle; my suggestion? Apply throttle and listen to some tunes, should quiet it down. :)
All 1GR-FE engines, be them single or dual VVTi seem to have this "Toyota Tick." Sources seem to range from VSC valves, rocker rollers, fuel injectors, ect. ...... :)
My 2013 FJ made the same sound, I was also informed this is normal for these engines by my local dealerships service manager.
Not worried!
I am reviving this thread because I have 3 5th gens and only my 2013 does this. The dealer told me it was normal and all of them do it. So.. I drove my 2010 to the dealer and showed them it does not make the noise. (this was several months ago)
They said they would log it in case there were problems down the road. When I pulled my 2013 out of storage the other day, the noise (it is inside my shop) sounds twice as loud as normal. Again my 2015 does not make the noise at all. Our 4th company 5th gen (owned by GD2013) also does NOT make the noise. Sou our of our 4, only one does it... This disproves that "ALL" of them do it.
Perhaps you should read the thread! :boxing:
There were several theoretical diagnosis but never an agreement as to the exact cause of the ticking noise and if it does in fact occur on all 5th gens.
The ticking on my 2014 comes and goes. Sometimes it gets worse as I get near an oil change, sometimes it gets BETTER as I near an oil change. Go figure.
Would love to have a Toyota tech or engineer explain it to me.
"doctor, I get this weird thumping noise coming from my chest. it gets faster when I run, but slows down while I rest! what could it be?!"
It's normal. don't worry about it.
I have a 1997 4runner with 205,000 miles and the engine has been making a loud ticking or clicking noise at idle. I heard that 4runners are notorious for making those noises after 200,000 miles. I want to fix it but I don't know where to start.
