False advertising on ground clearance
03_4x4Runner
Toyota list the ground clearance of a 2014 4runner at 9". On level ground in my garage mine measures 8 3/16" under the front skid plate. Toyota must measure it with zero gas and oil. By the time you add several passengers or any thing else it is even less. Also when you hit a bump and the suspension compresses it is much less also. Time for a lift.
you should sell it and get a lifted prius! :laugh:
Toyota list the ground clearance of a 2014 4runner at 9". On level ground in my garage mine measures 8 3/16" under the front skid plate. ...
The number of inaccuracies in the 4Runner Product Information sheets is surprising. Even in the 2015 specs, the Limited 20" wheel is still listed at 7.5X20, rather than the correct 7X20.
It's interesting that the Ground Clearance of 9.6" for the LE is over-stated, while the Overall Height of 70.1"/71.5" for the LE is under-stated.
so youre complaining about 13/16" of an inch of clearance? go get a lift, done deal
Technically, I think he's complaining about 5/16 of an inch, since rounding up after 8.5 inches is probably fair advertising. Is it maybe those goofy huge wheels and small tires on the limited that is causing this???
Get a H1 if you want to go off road in a full size rig. Around here if you go off reading in anything bigger than a side by side your crazy!
thats what happens with IFS
Could be, as would any other manufacturer. My guess is they probably also do the measurement on a completely base SR5 - ie. no weight of nav, XREAS, etc.
Well, yeah. That's pretty standard physics.
Time for a lift.
Whatever you need to justify it... :D
I was thinking time for a class action lawsuit. Who's on board?:wof:
"Toyota list the ground clearance of a 2014 4runner at 9". On level ground in my garage mine measures 8 3/16" under the front skid plate. Toyota must measure it with zero gas and oil. By the time you add several passengers or any thing else it is even less. Also when you hit a bump and the suspension compresses it is much less also. Time for a lift.
I only run 4x4 trails on the moon to avoid this kind of CR@P!
Gotta agree gravity is the Chit!
Please explain how the lowest part of your drivetrain gets lower when your suspension compresses.
