Show off your roof rack or cargo basket!
Yeah, I had the rack custom made to hold the cans and provide tie-downs. It is light weight and does not whistle on the freeway. :thumb3:
That basket you have there has possibilities. I would make sure it is strong enough to support the weight of one or two 5 gallon cans of gas or water. You dont want those to kiss the roof when you hit a dip!
Factory rail make it close, if you use the yakima cross bars it brings the rak up a couple inches, if it flexes that much something is wrong, obviously they use paper stuffed bags in the video, but I'm just posting it to show the height.
https://www.youtube.com/watch?v=sa8gJLpmmro
while this option does appeal to me, the price of the total package is over $400, and your weight limit is ~130 lbs. I am a little more drawn to the rocky-road rack, it's a beefed up cross bar system that can hold 300 lbs. My main want for a rack is for a kayak and possible gas cans, I can easily attach a kayak rack and gas can mounts to the rocky road rack when needed, and the price is about half that.
If you go the Yakima route, I think you can easily figure out some kind of rubber bumper/bushings to supper any kid of flex in the basket to protect the hood
The shape of the cans makes a difference as well. Notice I use 5 gallon cans that are shorter and wider than the basic "Gerry Can". This makes for a lower center of gravity for the cans, and a wider foot print to distribute the weight over a larger area. And there is left over room for more cans or firewood.
:lock1:
I think he said he had it made, if you're looking for something to fit between cross bars that is pre-made, check out the Yakima basket case
Does the Basketcase touch the top of the truck or is there enough room to low mount it that way?
I just found that picture online, I do't know who that belongs to. I did see a shot of it with the tank on and didn't appear to be hitting the roof. Those old trail side rails are a little taller.
I would love a Gobi or a rack from Drabbits (I met Alex and saw his shop, nice work and nice guy), but can't justify the cost at the moment for my use. I like the idea of the Yakima Basketcase if I can load a few things on it and not worry about it hitting the roof. I would love a heavier basket but need the roof clearance. I have the TE Racks.
Just got a Yakima Load Warrior but was not a fan of how the rack's bolts extend past the thumb knob adjustment nuts and poke out above the flat bottom. So I cut about 1.5 inches off of each bolt, ran a 1/4-20 die over the cut threads to clean them up, and used lock nuts instead. This way I can use a wrench to tighten them down instead of my hands.
With shorter bolts and locknuts
I had a Yakima on my 4th gen and hated how high it sat so I flipped the mounts around opposite of how yours is. Only pic I can find is this one
And here it is with the high lift mount. The axe and shovel are on the other side.
I know this is old, but where can you purchase this basket? I don't see it on the Yakima website.
No cool action pics but here's my non-lifted TEP with the Front Runner Rack.
