12-10-2014, 10:25 PM
TRD Pro vs SR5 maintenance/repairs
Wouldn't a TRD be more pricey to maintain and repair over time?
2014 SR5 Premium, Classic Silver
Tinted windows, OEM running boards,
Weathertech mats, Cooper Discoverer A/T3 P265/70R17
12-10-2014, 10:29 PM
Real Name: Charles
Real Name: Charles
No, They are 99.93% the same truck
Edit: Per
@1engineer
's detailed calculations I was wrong, the correct parts interchange is 93.934316% and is beyond contestation unless you have documentation to prove otherwise
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
12-10-2014, 10:36 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Dude, if you are going to answer him get it right. Its 99.934316%.
12-10-2014, 10:42 PM
Real Name: Charles
Real Name: Charles
when i'm wrong, i'm wrong
12-10-2014, 10:52 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
You weren't wrong but I wouldn't expect a guy with only a master's from MIT to carry the significant digits....
12-10-2014, 11:43 PM
Edit: Per
@1engineer
Doesn't it have more expensive components which justify the higher price tag?
12-10-2014, 11:58 PM
NO. All the part time 4wd 5th gen 4runners are pretty much the same truck and will cost about the same to maintain over time.
Pro - is a trail with different shocks, springs, tires, wheels
Trail - is an sr5 with a rear elocker, there is also an option for KDSS on this model only
SR5 - is the base model but really all the same components, just missing a few options like the e-locker and KDSS
The only thing that could be potentially more expensive to repair in the long run is the KDSS system.
The Pro will demand the highest sale price (compared to what you actually get). It's called marketing.
12-11-2014, 12:26 AM
Is it true that there is only a .5" difference on height between the SR5 and TRD?
12-11-2014, 01:42 AM
Real Name: CJ
Real Name: CJ
Is the TRD Pro only .5" taller than an SR5 even with the entirely different suspension?
Is there an echo in here?
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
12-11-2014, 01:53 AM
Real Name: CJ
Real Name: CJ
Yes. More expensive shocks, springs, a better and IMPRINTED TRD skid plate, a different grill, and of course those unobtainium cast TRD Pro emblems.
Get a set of Bilstein 5100's for your SR5, set em at .85" for a "close to Pro" look, or go with 1.75" and stand out in the crowd. I got 3 of these from Amazon for mine. I am reliably informed they are good for another 5HP just by sticking them on the body.
Build Thread
12-11-2014, 04:15 AM
12-11-2014, 05:15 AM
Real Name: Tom
Real Name: Tom
LOL I was gonna say something about sig figs, but you beat me to the punch. I guess my smartass credits are burned for the night.
OP: The question is really a non issue. The initial starting price is so much higher on the TRD that overall maintenance costs should not really matter. If you went all stock, the suspension and the recommended tires alone on the TRD would cost more over time, but initial the $8k+ out the door puts the TRD in a different price point all together. That said, the stock for stock maintenance costs will be the highest (over time) on the Trail and Limited due to KDSS and XREAS respectively. That said, anyone on here will probably opt to replace those expensive components with aftermarket items (that cost less while providing the same effect) in the event of a major failure.
2012 Trail (KDSS), Falken Wildpeak AT3W (E) / General AltiMAX Artic's, Level 8 MK6 (0), Pilot stubby, Max Liners
12-11-2014, 09:53 AM
Don't get me wrong, but most people who buy the TRD will never use the components that it has to over over the SR5. They will buy it for its looks since all the necessary mods are already done and covered under warranty.
12-11-2014, 10:20 AM
Its a Toyota.
2014 TEPP (Trail Edition Premium Pro), ICON S5 2.5, Remote Resi,w/CDC (Compression Damping Control), ICON Billet UCA's, Nitto Terra Graps, 285's, FN Five Star 17x8.5, SSSlimline Hybrid Bumper, Warn Zeon Platinum 10-S, Factor 55 Pro Link, Factor 55 Hawse 1.5 inch Fairlead, Metaltech OPOR Rock Sliders, KDSS, Sunroof, TRD Shifter & Engine Bling, Carbon Fiber Trim
1994 Limited, 257k Miles, 3.0
