Icon Lift question on T4R trail w/ KDSS
reluctantkarmi
I got the icon stage 3 lift and had it installed, but I was told that the rear sway bar hits the suspension (?) when it bottoms out (??)
The two mounts bolted on to the KDSS that hits the rear trac bar.. when I droop. So I am totally confused, does everyone else have this problem. Or did someone mess up on the install ? Sorry if this is patently stupid a question, but I figured asking can't hurt.
Warm Regards
Update : I called ICON and while they are looking into it, I wanted to see if anyone else maybe has a work around or knows something given my lack of comprehension of the subject matter.
you sure it's a "Stage 3"? those look like the OEM lower links.
I got metal tech lower links, so I guess its not icons links per se. The rest was the following
Std travel front coil-over shock kit with 700lb springs
Rear 2.0 Aluminum Series Shock
Overland rear 3" lift rear coil springs &
Icon tubular Upper Control Arms
not sure if that helps...
Are you sure it actually hits, or just get's really, really close? Mine looks like it is sitting on the bar at full droop, but there are no impact marks, and no nasty noises when catching a little air.
Yes, when I installed my lift and had everything dropped out, the panhard and sway bar were hitting, potentially limiting further travel. Will be looking into ditching the KDSS in the future. Damn, could have saved money had I known earlier.
[MENTION=113049]rochmpr[/MENTION]: If I knew earlier, I would have possibly considered another lift <..not sure that would not have this problem either to be honest. > and I sure hope ICON does come out with a fix..
[MENTION=78273]Jeremy556[/MENTION] - Def has a loud clang when I hit a ditch at a higher speed.. not very pleasant :( I haven't done anything offroad yet, since I just got it 3 days ago..
If I would have known earlier, I would have saved $1700 on the KDSS. The plan was to run the lift.
Might want to remove one shock and measure extended and compressed length, to make sure you didn't get long travel shocks.
The specs are probably around somewhere, but I have a spare set of Icon rear shocks on my bench and can measure if you need.
[MENTION=82005]jere[/MENTION]emy556 : I'll call the shop and have them check. [MENTION=114376]Mooney[/MENTION] [MENTION=101352]harkco[/MENTION] [MENTION=29376]sandcrawler[/MENTION] : Thats good to hear, maybe I just got unlucky.. I'll double triple check..!
Thank you for taking the time to reply.
When I installed my All Pro rear springs I messed with the suspension a little to see full droop on the rear kdss sway bar. I noticed when I lifted the rear end up by the bumper using a jack the panhard bar made contact with the sway bar.
I took notice because of the noise it was making.
Nothing hitting on mine either. Have been running Stage 2 with KDSS for the last 4 or 5 months.
Do you have extended travel front coils? These come with the stage 2. I was surprised the OP has stock travel front coils with a stage 3 kit.
[MENTION=116276]reluctantkarmi[/MENTION] maybe it's because of the 3" Overland rear coils??
Do you have extended travel front coils per the stage 2 kit?
No I have standard travel front coils.. :ohwell: maybe thats why, i'll call metaltech again, been playing phone tag. I went with what they recommended since I was new to the whole thing. :cry::cry: god i feel stupid..
Even with stage 2 extended front coils Icon says "compatible with KDSS".
I don't know enough about the mechanics but could be be the 3" rear coils? sandcrawler and harkco have the normal 2" springs, they don't have rubbing issues.
Extended travel front is fine with KDSS, as long as you have aftermarket UCAs.
On the rear, the shocks are what limit down travel, the springs don't matter.
" No, they changed the track bar. So any coil will do this" - ICON ... I am told their engineering team is looking into this, so I will update this as and when I hear anything.
Thank you all for everything. Hopefully they come up with a fix soon!
