TRD Mods
Ive few so far. TRD wheels, Skid Plate and Oil Cap. Now TRD shift knob coming up. Any other ideas on TRD stuff? Any suggestions on shifter install?
For those that have installed the knob I have a question. Are the shifters on the 15's longer? Cause it lists it as an add on for the 15's but I know on earlier ones you need to add a spacer. Also will it fit the same on the 14's as it does on the 15's? Gonna pull the trigger on one soon and just wanted to prepare if I needed any other parts.
That looks to be the same length as the OEM one I replaced on my 14'.
I don't think they changed the length of the stem.
wait, are you saying you got the new TRD Pro aluminum front skid to fit on your 2013 Trail w/ KDSS? if so, please post pics. it is my understanding that it won't fit bc it will interfere with the movement of the sway bars. :confused:
Had to trim the plate. As for shifter, easy install, direct fit (no spacers needed). Changing gears feel heck a lot better not to mention the look improvement. I did torque it to 83 ft/lbs since it is drive train essential part :) TRD Brake pads next when new pads due. CAI is a great mod but I"m not big fan of reusable and washable filter.
I got that shift knob before I had my truck at port. Very nice feeling in the hand for working the transmission.
I feel in love with this engine candy...really classes up the place.
Perfect fit and no interference with gate plate. Make sure you order 2015 4Runner part, because nearly identical shifter is available for Tundra.
