Jicko Build Thread ...
So, tell me about why the replacement warranty is a good thing? I failed to see it (I looked at that before when I buy previous passenger car tires). It's like $30-40 per tire.... and you need to purchase for all 4, so that's basically 1 tire worth of cost.... most of the time they can fix the tire if it is a puncture, and these BFGs are tough, I don't know how they can be damaged beyond repair. And is the warranty good for "offroad" activities too?
Just realized I hadn't responded to this. I had BFG ALL Terrains about 10 years ago. They had about 15K miles on them when I got three flats in a row on the same tire. Not from serious off roading or anything, just a screw and such. Seems like one of them was something I picked up on the ranch. I had the warranty on the tires then and went to Discount each time to get it fixed. Third time I went in for a flat fix(in about 2 months) they just said we are going to give you an all new tire since you have the warranty. I thought that was great and went ahead and got the warranty again this time. That was a different town and who knows if the local store here would be so accommodating now. Cost me a little extra money, but I'm good with it. Might never need it, but it's there anyways. Peace of mind for me I guess.
Hey, nice ride :thumb3:
Hows the color of your 3M tint? I can't seem to find a place that can match the grey color of the privacy glass and it just turns out green. Is yours the same?
Factory front 2 comes with a green-ish 70% tint. Factory rear comes without the green, but a grey-ish probably around 30 to 40% tint.
So, you will NEVER be able to just apply something to the front to make it 100% inside/outside match.
Theoretically, if you apply some greenish film to all the rear, and you then apply some grey-ish film to the front, you would be able to get them both progress towards each other, but that is a lot of work, and very much unrealistic.
Anza Borrego Desert State Park - Metal Dinosaur Hunt & Slot Canyon Adventure
287 Miles
17.1 MPG (reported by the factory meter)
Trying to stop a horse fight
A rex
A Serpentine span across the road
The amount of details is AMAZING!
Scorpion vs Grasshopper, each of them are 2 4Runner size!
Getting out to the trailhead of "The Slot" (aka Slot Canyon)
Heh, We came close this weekend. The very last bit of offroading with a friend we came up the buttes pass trail with a side trip to Hawks Canyon which is just on the other side of a ridge from the slot canyons...
End of a LONG weekend, offroading near Indio, Imperial Dunes, Truckhaven and Ocotillo wells.
Where else did you go?
287 Miles
A rex
This is awesome.
You should have parked next to more of them to get a better size reference!
man, i love anza borrego, can't wait to get out there again soon.
it's been 5 years already, and it wasn't even my own vehicle back then (was without 4wd for many years)
Low beam H11 HID bulb (only) retrofit on 2014+
Between various bulb colors, and various vendors, I have selected XenonDepot ExtremeHID kit with H11 4300K Genuine Philips bulbs: <a href="http://www.amazon.com/gp/product/B008TDAHQ2/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B008TDAHQ2&linkCode=as2&tag=jickrevi-20&linkId=BV2RGZOT7FDISH2H">XENONDEPOT XTP-H11 - H11 Xtreme Digital HID Conversion Kits - 4300K Philips Bulbs</a><img src="http://ir-na.amazon-adsystem.com/e/ir?t=jickrevi-20&l=as2&o=1&a=B008TDAHQ2" width="1" height="1" border="0" alt="" style="border:none !important; margin:0px !important;" />
Box opening:
Dry practice, it is good to lay everything out, wiring it up once, and convince yourself that you know how to hook everything up later:
First thing you need to do is to drill an 1" hole thru the headlamp socket cover (if you are worry, OEM toyota replacement part number 8113524160 $12 each):
Then you should fit the dust seal onto the socket cover (one tips, see the "blue" clip on one of the plug? remove that it will fit thru the 1" holes):
After your remove the stock bulb, connect the factory plug to the mating plug of the kit's relay. And then fit the HID bulb into the projector bulb socket. (one tips, remove the black ring spacer from the HID bulb protector, and leave the cap of the protector dangling):
You would have to cut off that cap:
Right side, assembled (protect loose wiring with wiring protector):
Left side, assembled:
Finished looks, extremely pleasant color!!
This pic is for comparison, this is the "before" pic:
Its TRD color scheme!
Starting as your standard silver TRD skid plate:
Blackend with 5 layers of BLACK Plasti-Dip, leave it to dry/cure for 24hours, then apply masking tapes:
And newspaper:
Then spray with RED Plasti-Dip:
Wa-la!
Matched quite closely with my TRD wheel's hub:
Can't wait to install it onto the beast!!
TRD skid added!
Installed it before work this morning
Shrockworks Rock Slider Installation
Finally get around to do this.
Shrockworks 2010-2015 Rock Sliders, 5th Gen
- Textured Black Powder Coat
- Dimpled Thread Plates
First off, no "TE Rocker Trim" needed, I believed 2014+, SR5 and TE has the same trim. Only Limited need the "TE Rocker Trim".
Arrived nicely packed
Comes with more than enough hardwares, note the 1.25" "silver" bolts, there are only a couple, and they will be needed(should be reserved) for driver's side, rear mount, where you have the additional "gusset bracket"
The box acts as a nice "lift" to set the slider in place. A few pieces of cut'ed up 2x4 on top of the box will get the slider in the perfect position. (Thanks [MENTION=94476]trail ranger[/MENTION], for the tips: LINK)
Driver's side, rear mount, is the trickest of the whole installation. One tips here - try to install the slider with minimal gas in the gas tank, that will help!! You would need to unbolt one side of the gas tank skid (4x bolts), and then the 1 bolt from the gas tank strap (and this is worry-some, cuz nothing will be holding the weight of the gas tank). So, I make up an adhoc support using ratchet sockets and support the bottom of the strap when I have all 5 of above said bolts off.
This is how the mounted driver's side rear should look like:
The upper most bolt needs the 1.25" long silver bolt. Another tips here, when you are under the car, and cannot look into the "upper" hole to align your "stick nut", a little play doh and a small mirror can make the job so much easier (sticking it 45deg to the bottom of the car's body, so that you can see straight into the upper hole).
Driver's side front, the key here is to do the top 2 bolts first (screw the 3rd bolt in a few turns tho), get the slider's front/back level, tighten all other bolts before cranking down the lowest/3rd bolt for driver's side front mount. There will be a gap, and when you crank it down, it will bend the piece, and close the gap. Nothing to worry about.
Now, passenger's side rear. For the lowest bolt, a tips here - there is an access hole at the inside vertical wall of the frame, open that hole, get the "stick nut" inside the frame, and come out the hole besides the lowest bolt spot (see pic before), it make aligning that lowest bolt so much easier!
Passenger's side front. Set the slider in place with the 2 upper bolts, then I just drill the 3/8" hole with the slider in place. Then put a "stick nut" behind it thru the "square hole". Again, there will be some gap, so, cranking it down will close the gap. The 2nd 1.25" bolt should be used here (my package only came with 2x 1.25" bolts).
Wa-la!
Wow, you're all set!
So lets go out next weekend!
Actually there are a couple of people that have called for an outing, getting late in the year, not too much time left. We should try to get like 4-5 people and head out next weekend.
Depending on the location and difficulty, I'm in SD as well if you're looking for another truck!
If my Gobi comes in next week I'll be installing it Sat. If not, I'd be down.
