What HID/LED company are you using? post pics
Socal4RunnerTrail
Installed my Diode Dynamics H11 low beam 6000K hId's today and ran there HD waterproof relay harness to the battery instead of relying on the oem harness. I love the way they came out! I tucked all the wiring underneath the radiator support and placed the ballest behind the flap of the fenders so there is nothing you can see
[/URL]~original[/IMG]
Removed the plastic support cover and ran under the support
[URL=http://s622.photobucket.com/user/s13nissan/media/Mobile%20Uploads/20150310_144641.jpg.html][IMG]http://i622.photobucket.com/albums/tt306/s13nissan/Mobile%20Uploads/20150310_144641.jpg[/URL]~original[/IMG]
Used existing ground to ground hid's (so convenient!) Also tucked everything under that fender liner flap
Ziptied relay using the existing holes on headlight bracket
All back together
Drivers side
Passenger side
P.S
Push little plastic clips down to remove radiator cover they come off easy
Also installed a led DRL bulb from Precision LED'S
Premium 9005 21 SMD 5730 LED
2014 Toyota 4Runner Fog Light HID Conversion Kit - 4Runner - Toyota - Bulbs By Vehicle - Lighting
is the high beam bright? and is the drl dim? some have said that even with the low voltage with the drl it will be full brightness which means you'd be riding round with your high beams on.
High beam is as bright as oem i think, and the drl looks amazing and isn't overpowering
so what is the best option to get i have an 15 limited and want to upgrade the headlights because i do mostly night driving?:beer::beer::beer::beer:
I bought some wire loom from HD/Lowes to hide all the extra wires from my HID kit, looks practically stock.
Also, hid my ballast in the same spot as you did.
I didnt bother to use relays on my HID kit. My lexus doesnt have relays and it fires up just fine so I figured if my old lexus can handle it so can my 4runner.
Looks awesome, if your doing some night driving can you get high beam pics...I don't want to lose any light output. I do a lot of night driving.
My Diode Dynamics low beam 6k hid setup is awesome for night driving, no high beams needed ran me $185 with heavy duty waterproof relay harness
If you low beam is sufficient for cases that you actually need high beams, then your low beam is too bright and aimed too high (and definitely blinding people)!
2015 4runner with the Morimoto LED fogs installed , just ordered the HID set from TRS 50w - 6500k for lo beam, havent figured out the high - DRL beam yet.
Pm
Socal
I sent you a response to your PM to me did you receive it? My PM profile does not show any message sent in my sent queue. So I don't know if you received. Thats why I'm posting this.
Socal
Updated tou with my address thanks!
Thanks for fixing the pics.
You mounted yours similar to the way i mounted mine. Good deal.
Np man thanks for letting me know, i love how toyota put that flap there makes it all look clean
