DIY Leather Steering Wheel
Researching this option at this point.
Findings:
1. Price and store
Amazon.com: Black Genuine Leather Steering Wheel Cover for Toyota Land Cruiser Prado 2010 2012 2014 Tundra Tacoma: Automotive
51IpwNfZoWL.jpg~original
2. Installation examples
Leather Steering wheel cover '14+ - TundraTalk.net - Toyota Tundra Discussion Forum
803F0479-4ADF-4B7F-A9A4-B97709AC12EE_zpsmox7csxy.jpg~original
70F491A8-FDB7-44C9-BA04-BF4652321876_zpsf1gsmlzl.jpg~original
A50D0A3F-9C20-4202-9B9B-32B4E792A308_zpsbva1xavx.jpg~original
3. Optional Steering Wheel trim removal
Tundra to Tacoma steering wheel swap? - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
photo1.jpg~original
4. Kelbad's link
http://www.toyota-4runner.org/5th-gen-t4rs/195438-xuji-leather-steering-wheel-cover-install-goodbye-plastic-steering-wheel-oem.html
155671d1430366615-xuji-leather-steering-wheel-cover-install-goodbye-plastic-steering-wheel-oem-wheel-1-hints.jpg~original
Well, I bought one from Amazon, will let y'all know how it turns out this weekend!
Should be here tomorrow, or so Amazon says...
Okay, that was a lot of fiddly work, dammit! I'll be honest with y'all, I am definitely no seamstress, and I would not tackle this one again! No, it wasn't super hard, but it was a long, drawn out process to get it done right! Lots and lots of internet videos to get this one done, but I have to say it feels a LOT better than the sticky rubber wheel that was damaged by the last owner's hand lotion or whatever the hell he/she used!
Okay, pics...
Here's the kit, pretty nice and pretty good quality leather if you ask me:
Extra tools that I thought I would need:
Yes, that's a beer! One of my Full Sail Bourbon Barrel aged stouts was REQUIRED at the end of this job! Trust me, get beer. Lots and lots of beer! Mine is 11.9%ABV, that equates to almost 4 regular beers, you will need more. I know I do...
Leather close up:
Double-sided tape installed on the leather:
I found that I needed more than what they provided me, luckily I own a sign shop and the tape is nothing more than "banner tape". We use this stuff to hem banners, rather than actually stitching the banners, its very, VERY strong double-sided tape. I assume you could use carpet tape too, that would probably be pretty close too, and probably not nearly as much as my 10 dollar roll costs!
I cleaned the steering wheel with isopropyl alcohol to get as much oils and dirt off of it before starting, but I definitely put way too many other chemicals and oils on the rubber to remove the sticky feeling in the past 4+ months! I ended up having to use 3M's "94" tape primer on the wheel to get the tape to stick in a few spots!
Placement of the leather:
Take your time here and make sure to really get it centered and aligned well! I spent 20 minutes doing this, I should have spent another 10 minutes to get it closer! The wings were slightly off and the upper part was not perfectly straight. I got it moved while stitching, but it was not easy nor fun!
First stitch, I started at the bottom:
Good thing too, as I didn't have enough thread to finish it! I had to search around to figure out how much thread is needed! What I found was 6 times the length of the piece I was stitching worked well. They give a good amount of thread, so some waste was just fine and I still had about 4 or 5 feet left over.
Second area stitched up:
Lots of fiddly work here, getting around the corner and stitching up the back side, then tucking it into the plastic covers. I used more 3M primer and a few tiny strips of tape to make it stay for good.
Yeah, this is a pain in the ass:
Finished product:
Overall, I'm very happy with the way it turned out, but it took me close to 5 hours to finish it, with about an hour searching around the 'net to figure out how the hell to start the stitching
I even had to figure out how to thread the needle properly, didn't see anywhere that said you have to pull the thread through the needle halfway, tie the ends together, trim excess string right up against the knot, then thread through the leather on the back side, from the inside first!
My fingers are definitely sore now, you pull on the thread quite hard to cinch the seam together. I thought for sure I would tear through the leather with the amount of tension I had, but I didn't, surpringly!
Took the vehicle for a quick drive and must say it feels really nice! Looks completely stock and doesn't twist or spin on the steering wheel, which was one of my other concerns about this "mod".
If I have any issues with it down the road, I'll post back here, but I doubt there'll be any---I hope!
Oh yeah, couple of things to do before the install if you wanna make it less painful!
Pull the horn fuse under the hood! 4 beeps was more than enough to piss me off!
Pull the bolt out of the pinswitch for the door, you'll go insane if you listen to the dinging for 3+ hours while you turn the wheel back and forth! You don't need to remove the switch, just pull the T35 bolt out and the dinging will stop.
Crap! Just realized I didn't put that back in...
Oh well, you'll want to either jack the front up to make it easier to turn the wheel. I just stuck some backing paper from my vinyl under the tire. That stuff is teflon and makes the tires turn nice and easy on my shop's floor!
Get several flashlights that you can aim at various angles! I must be friggin' blind, because it was very hard to see the stitching without two lights on the whole time, all the windows down, including sunroof and my 12-8 foot fluorescent ceiling lights on the whole time!
Now, time for another beer....
Very nice. Now maybe you will quit *****ing about the sticky steering wheel :hiding:
LOL! Nope! I won't. I'll continue to whine about it.:mad2:
Sure glad you didn't wanna get that done too while you were here!:eyebrows:
congrats and thanks for the write up, you are infinitely more patient than I am I probably would have just went with one of these
That is outstanding work and great results, flyinhavaiian. I'm planing same thin with addition of wheel tape on the top of the wheel to increase thickness between thumb-rests there since it much thinner by design. Do you think this kit will stretch another 1/8 in on the top there? What was your source on how to stitch? Did you say there was not enough tread?
JOES Steering Wheel Tape :: Kartek Off Road Parts & Accessories
There was plenty enough thread with the kit, but not enough of the double stick tape, which is why I used my banner hemming tape (I use the Cascade brand):
Pre-Made Banners and Banner Material - Pacific Coast Sign Supply® - Sales - Service - Support
I guarantee that you will not be able to fit that under this skin! I had to pull the thread extremely tight to get the two ends to meet up, and feel the kit could have been just a tad bit wider to make it butt-up together a bit more. There were a couple of spots where it simply did not butt-up tightly, but I could not pull any more on the thread for fear of ripping the leather or snapping the stitch.
As for the source of the stitch itself, that was about 7 or 8 replays of the XUJI video with that guy going warp speed on stitching a wheel! I also used a couple other vids on youtube on "steering wheel stitching". After watching about a billion vids, I just said screw it and jumped in! I did the bottom piece first just so I could re-do the smallest and easiest part if I screwed up. And I did!
I didn't allow enough thread to finish the whole piece, so I couldn't finish the last 10 stitches. Ended up cutting the needle out and pulling out that whole section of stitches. Back to youtube to see how long it should be. That's how I came up with having the thread equal to 6 times the length of the area you're stitching. There will be leftover at the end, but there's plenty enough to finish the job.
Of course, I also kept the remnants, just in case I had to McGuyver the last bit of stitching!!!:eyebrows:
Completed this task yesterday. Good results, but it isn't easy to make perfect. I removed the steering wheel to get best finish. I will post final pics in few days (lil busy now).
Take a look at wheelskins.com I bought one through the dealership I work at and I cant wait to get it. I'll post pictures when I am done.
It is not PIA, you just have to be patient and align everything just right. Treading it is the easy part. The best $50 Mod I ever done.
I have been waiting over 3 years for someone to come out with a nice steering wheel kit that would not look cheap, this one looks better than I expected, ordered mine. headed out to a horse supply store to get some saddle soap, it is a cream that softens leather, specifically saddle leather, I have used it on past steering wheel cover installations I work in a bit before hand on the inside, then once done I put on leather driving gloves and rub it into the steering wheel cover after it is installed, it smoothes out any rough edges and helps the leather take shape while acting as a preservative. cant wait to get mine.
