Cooler Rack or Front-end Rack
kittyhawksurf
I tried searching for this on the forum, but I can't find one anywhere.
Has anyone figured out how to add a rack on the front of the 5th Gen 4R? It looks like it may be a nasty project to try this, but this is my Expedition and I cannot live without one on the front anymore. Used for a cooler and beach toys mainly. Absolutely imperative for camping.
image1.jpg~original
[/URL]
image2.jpg~original
[/URL]
image3.jpg~original
[/URL]
Sweet ride.
Seriously... never seen such on here. But at least one member has put on a front hitch, if you could make that work. Looks like a welding shop is in order. Chop up a couple receivers, weld 'em on.
Front hitch + hitch carrier = what you're looking for.
FYI there are two front hitches from Curt - one is lower than the other. I don't recall which is which. I have the one that tucks up tighter that I removed when I installed a hidden winch.
I don't like hanging heavy stuff off the front end. The IFS isn't well suited for this type of use and your handling is likely to suffer if you put a 200lb cooler cantilevered off the front like that.
Why the front?
Why not just get a swing away hitch mount on the rear? It would be more protected and have less of an affect on handling. Probably cheaper in the end.
Here's a basic swing away frame you could customize how you want:
swing-away hitch
Sweet ride.
Yea, dude. I know. That rust on the front is custom and it took years to get like that. Don't be jealous.
I have never heard of Curt. Super cool. That looks like a pretty good solution, but yea I need to be careful how much weight. I know that front rack on the Expedition weights 100 lbs and I've put another 200 lbs in it. Brakes get worn out fast, but it's worth it.
swing-away hitch
I'm pulling a camper when I use the cooler rack unless day surfing. Swing is a good suggestion, but way more a pain in the @#$ than a front rack.
