2014 Trail Edition Transmission Cooler?
jtex
Can anyone tell me if the 2014 Trail edition has a transmission cooler or not? I will be doing some towing occasionally, want to address this as my first mod if the runner does not have a trans cooler. Thanks.
Yes, integrated with the radiator.
When you say integrated, are you referring to the 2 radiators that are visible, or is the trans cooler inside one of those? Apologies for my cluelessness.
The bottom of the big radiator cools the transmission fluid with the same antifreeze that cools the engine. There is a liquid to oil cooler in the bottom.
Auxilliary trransmission oil radiator
You can also add an added transmission cooler, eliminating the lines through the radiator. Or maybe in addition to, downstream from the engine radiator. Someone here recently suggested the engine radiator also serves to keep the transmission fluid warm on very cold days, but it can't do this until the engine warms up several minutes after starting the car.
