How to: Center Console / Shifter Trim Removal and Cean
SKP-4R
At the request of [MENTION=124732]LawnDart[/MENTION]....
Before the write-up, big thanks to [MENTION=102715]CrazyNorwegian[/MENTION] for the tips. It is fairly straight forward, but I figured a more detailed in-depth look at the process might benefit a few folks.
*There are no tools involved, just a little bit of elbow grease and finessing with clips.
1) A obvious first step would be to remove the shifter nobs. That includes the transfer case as well on Trail and Pro models.
2) The second step would be to pull up on the back cupholder. Place your right hand in-between the cupholder and outside of the center console and give it a good tug. This undid almost all of the clips.
3) Before I worked my way up to remove the last few clips near the transfer case, I unplugged the rear window switch located beneath the rear cupholder. After undoing the rest of the clips, the center console should be free to wiggle out.
4) The next step is locating the 4 clips around the transmission trim area. There is one at each corner. Simply pull out on the tabs and the trim should lift up
5) A similar type of tab holds the clear plastic shield beneath the trim that was just removed. Once that is removed, you can lift the rubber dust cover away to get down to the plastic.
(steps 4-6 are not necessary if you are installing light switches)
6) If you are cleaning this area like I am, the last step would be to get a moist wipe to reach all the area's that need to be cleaned. There was a fair amount of soda residue that had turned syrupy which was my main reason for cleaning. Be careful not to touch or remove any grease on the shifter itself or the shaft that leads to the transmission.
7) Reinstallation is the opposite of what you just did, making sure to connect the rear window switch before you press everything down.
Bellow are a few helpful photos taken during the process. Hopefully you never have to need this thread unless you are installing switches, but if you do it is not that hard.
What were you trying to do?
Slammed on my brakes to avoid an A**hole who ran a red light. Spilled soda all over the shifter and center console. Transmission shifter and rear window switch were very sticky. After a good clean it was better than new
Nicely played. I may swap that panel as mine took some damage from some gear I had in the front seat.
Hi SKP-4R,
I'm really diggin' that 'Gun Metal' gray console! I may consider doing a repaint on mine for my next mod; thanks for your post!
rigtec, Cheers!
Hi SKP-4R,
rigtec, Cheers!
It's just the normal trim that's on the face lifted Trail models
Hi SKP-4R
Yeah, I've yet to be in one but I'm lovin' that 'Smoky' depth and color... I can see that this has got my wheels turning e.g., Head-unit trim, center console... 'not sure how far I'd want to go', but definitely the center console; very compelling! Best!
I don't usually respond to these, but thanks for the writeup... I had the same issue with a soda and just cleaned mine all up.
This was an awesome write up. I'll probably swap my console out in a few months when I have 350 to spare, since the trails console is the most expensive due to the buttons and whatnot.
Console cover removal
This is a great write-up. I'll be giving this a try. Now I can remove the console cover and install those RAM Mount brackets on the side of the console.
I don't think Trail center console trim works on SR5's because of the physical transfer case level that sticks out.
You're right. There's another thread that we concluded this. It has to do with the top cupholder layer that can't snap into the base layer. The Trail trim piece has a giant hole where the transfer lever goes. The fit isn't snug and will require a lot of "ghetto rigging" with duct tape. :P
Stupid question and hopefully you see this:
How do you remove the transfer lever knob? Shifter knob was easy. The transfer knob was really tight. I didn't want to break it by twisting too much.
2019 TRD.
Thanks for the post! Saw this and with the photos for clarification I went straight out and took mine apart for cleaning and removal of a small screw from the plastics around the shifter!
