Headliner Crud?
Antman
The exterior of my truck isn't really too clean these days, but I do keep the interior really clean- well, except for the headliner.
I just noticed all these stains next to all the window openings. I'm guessing camping dirt, soot from the campfires, etc.
I know you guys demand some quality photography so I drug out the dslriPhone for some Hi Def images.:snacker:
Anyone have any suggestions on how to clean this without ;
a- Smearing the dirt everywhere.
b- Piling up the mouse fur material.
c- Causing the material to separate from the backing at a later date.
d- Leaving watermarks
Thanks.
dirt on headliner
I'd try vacuuming with an attachment that has reduced suction. Something that lets some of the suction enter through a side hole or slot. Or hold the vacuum tool partially off of the tube. I have a shop vac' I'd use.
That's the easiest way if it works. You can try this without getting it wet.
Good luck,
Dave
Same shit happened to me. Broke out the carpet cleaner with non scented detergent. Came out like a charm
You sure those aren't [MENTION=47340]Titanpat57[/MENTION] "tracks"? That stuff is really hard to get off. Ha ha "get off" ... I slay me.
I have one on the passengers side, by the handle, which I think is a leak. All kinds of stained goodness. I'm guessing, but probably what [MENTION=65614]Antman[/MENTION]'s underwear looks like at about the forth day...like someone hit a deer
Before reading any replies I knew this thread was going to be good. Both informative and funny :clap2:
I was thinking about this the other day. I had just pumped gas and went to lower the visor to block the sun.
I looked into future replacements and found some textured and perforated vinyl that would be easier to clean and not stain as easy, while matching the stock interior.
[MENTION=65614]Antman[/MENTION] do you have a moment to talk about Nature's Miracle?
When I graduated from college I moved into a new place and was in desperate need for a couch. I got a few terrible couches given to me, but my mom works at a law firm that happened to have a $5000 designer couch that they were selling for $300. I went to look at it and someone had spilled printer toner all over the left side. I had just got a puppy at the time and since she was still learning to control her bladder I had plenty of this stuff around http://www.amazon.com/Natures-Mirac...pebp=1441080742801&perid=1AVNSZ1P175KNSF4GXVG. I took it to the couch and got the stains right out and off I went with my designer couch.
tl;dr Nature's Miracle saved me thousands of dollars
I recently moved a new to me grill and I had all kinds of black stains on the headliner after. I used this stuff and it's back to new.
You should ask your mom for her opinion on the Gobi/whitson case.:tongue:
I should try this as well. Since Antman pointed out those cruddy spots I've been thinking about this. I have dogs = I have Nature's Miracle. I'm guessing the reason it works so well is because it is enzymatic and does not contain ammonia like Resolve or any number of other cleaners. The worst spots I have are next to the coat hooks in the back seat.
and the sliver of headliner at the top of the liftgate opening, i'm guessing. i've just resigned myself to accepting that, while otherwise being light grey, that portion of the headliner is "dark grey" :)
I'd clean it with a bucket of water, some carpet cleaning soap and several towels. Get it nice and wet, clean it real good then dry it lightly with another towel, then air dry for a few hours.
All you need is some elbow grease.
Do you know the previous owner? I bet they were a smoker.
weeeelllllllll....
Being you opened that door...I'm going to swing right in there....
The only smoking the owner ever did was pole smoking....I don't think I want to know what those stains are..
I am the only owner of my 4Runner. Never been a smoker and don't allow it in my truck. I think the crud buildup is from riding with the windows down, so a collection of pollen and dust/dirt.
weeeelllllllll....
I'm just gonna let you have a little more fun at my expense before I thank the nice folks that actually had helpful responses.
Pole smoking- lmao.
