A New version of "Entune" is available!
Entune update
Sorry about the early 2014 part of my question,I must have had a senior moment. The 4Runner was indeed built in Sept 2014 so it was a late 2014.Now my question is still does the entune update improve the navagation part in any way? Thany You"all.
Does anyone know if this update (5.1) effects or improves anything in the navagation part of the entune system on an early 2014 SR5 built in Sept 2014?
Hi gbarr,
Yesterday I dropped in the 5.1 O.S. update. Today I drove my truck about 140 miles; down the jersey shore area. I noticed the Maps have changed 'FOR THE BETTER'! It now shows the Interstate signs Route 80, Route 95, Garden State Parkway... as you go past them, and a few other nice changes! The Phone seems to hook-up (pairing) more quickly then before. ...Before, after getting off of the phone the music wouldn't come back on until I turned the volume up or down, but now it starts playing as soon as I hang up the phone! NICE!
Good deal [MENTION=83083]rigtec[/MENTION]
I still haven't had any luck on my 14. I think I'm on 3.2 (almost positive) but I can't see where it designates which version I'm actually on. I've gone into all the proper menus but no luck.
I did however find where the source code can be downloaded. Maybe the programmers among us can figure out some of the units limitations.
Here's what my update etc screens look like:
[MENTION=64999]mdrudy[/MENTION],
That is the same as mine.
Cool...all this Entune and dealer games is kind of a pain. And not sure why update history doesn't list any updates??? I updated when I bought it new in April 2014 and again just a few weeks back. Maybe the Entune OS updates don't get listed under the update history??? Hell if I know.
And here's a link for the source code download:
http://car.panasonic.jp/oss/c01vvt13/
Here is my fuse box.......
Looking for the correct fuse for the HU.
For those of you who would like to use 'VISUAL' assistance to locate the fuses that protect/energize your headunits:
See (below) the RED and BLUE arrows on the center right-hand side; the Blue arrow acknowledges the Accessory circuit portal (marked ACC) at the headunit. It's function is intermittent: Hot when ON or in START, and protected by a 7.5A fuse. This circuit is de-energized when the vehicle is off. You can follow this Gray wire across the diagram to line number 8, where it leaves the page; you can ignore the hand written arrows on the left-side, N/A.
Next, they both pick up on the adjacent page below, wires numbered 8 and 9;
Here, the Gray wire (number 8) goes to the top of the page where it connects to a 7.5A fuse; as highlighted by the blue arrows. If you follow the RED arrow, it too starts at the hu (marked B+), travels across the diagram page (Blue wire #9) and follows the path that ends at the 30A amp fuse.
Here's the 30A Amp Fuse location marked by the red arrow.
I'm hoping that by pulling the 30A fuse and draining this circuit for a minimum of 4 hrs, the headunit will reboot, deleting corrupt files and allowing an O.S. update (5.1) to take place. Rgds!
Hey [MENTION=103267]Saker[/MENTION],
That's it... I guess I was WAY TOO SLOW to post, 'never fails' hahaha!
Nice info and diagrams...thanks big time for leading all of this.
For some reason though, I don't have that 30 AMP fuse or the 7.5 next to it.
Okay I see that... What's labeled on the cover(?); One of those 30A fuses is your AMPLI FUSE, hu couldn't operate w/o it! BTW: the 7.5A fuse mentioned in my above post is located in the driver-side fusebox, sorry... I didn't make that clear because you don't need to pull that fuse; turning the vehicle off de-energizes the circuit!
Cheers
Got it...thanks. Top right corner of the inside the truck fuse panel. Second from the top. The 7.5 one. Check.
Haha... sorry bro,
No, not that fuse! There's a fuse that's 'HOT AT ALL TIMES'; it provides the hu with constant power that allows data to be stored in your navi's processor/hard-drive. Every so often, the processor files get damaged from constant use, file transfers, stored but un-used temp/broken files... much like your lap-top or phone. So pulling the 'HOT AT ALL TIMES' Amplifier (Amp) fuse helps to improve the performance of your navigation system. So you may need to drain that circuit so that the hu can revert back to it's original/default state of operation; much like System Restore will do for your computer. Look in the main fusebox for a 30A fuse that is energizing the hu. It's there somewhere, Cheers!
Greg,
The photos of my cover and fuses are with everything installed as found.
I do not have a fuse in that 30A AMP location!
