Light bar Q
kaos5000
Does anybody have pics of the wire running along the windshield, mounting of the relay and running into the firewall?
Thanks a ton!
I was feeling in a good mood so I decided to go outside and take some pictures for you if my install. I would highly recommend buying a light bar harness, it makes things easier and much fast.
I just pushed the harness into the channel seal and it holds pretty tight.
Then I ran it along the windshield down into the cowel right next to my ditch light bracket.
Here is the photo of the batter and where I mounted the relay. With the prewired harness and me being too lazy to extend the wires this is where I mounted everything.
Then to get everything through the firewall j used the main wiring harness grommet. I heated up a coat hanging wire and pushed it through and tapped it to the harness and pulled it through. It took about 3 tries to get it through because the hole want big enough.
Hope this helps you with your install. [MENTION=110029]kaos5000[/MENTION]
[MENTION=121759]Davy180[/MENTION] LOL race through puddles much? :biggrin1:
Sorry off topic
Lol only a little bit! I tried to clean it once and it didn't go so well. We don't get much rain here in California so I always take advance of the little bit we do get.
That's great, thanks for the pics bud!
