Trd pro lift question
Just got my 285/70 KO2 put on and there is no rub! Now I am at Toyota getting my SPC UCAs and an alignment. Hope that dose not change it.
you should be fine. BFG's don't actually measure tru to size like the Nittos do. The 285 ridge grappler will require pushing fender liner forward, possible bumper trimming and possible mudflap removal.
This is not an absolute. Factory build tolerances vary even across same trim levels. None, some, or all the above may/may not need to be done.
That is true just pulled into the driveway and when the wheel is turned and go up the bump there is a slight rub on mud flaps. Will have to either heat the flaps and bend them in or take them off.
Took a lil longer than expected but here are comparison pics. Stock and after the lift I put on.
need help
So got to installing the kit today only to find out our spring compressor won't work for the front shocks. What recommendations do people have for a spring compressor for the front shocks? or just send me to a forum that has the answer... I just can't search anymore...
I had that issue when I did mine, my spring compressors that I had used on Tundras and other trucks wouldn't work on the 4runner, I found a YouTube video showing how to do it with using the truck and a car-jack. I believe it was this forum, I'll see if I can find it again.
Well I ordered the Toytec 2" kit last week (hasn't arrived yet) with the full intention of running 285's. After flopping back and fourth 100 times today I ordered 255/75/17 STT Pro's (32" x 10.2"). These fill fit and flex without rub, weigh less than 285's, came in C load, keep my suspension stock, eliminate install/alignment cost, save mpg...all things that helped me make my decision.
I've looked at pics of 255's with the lift and it does look great but my dilemma now is do I still run the lift? Other than appearance I don't think there's really any advantage of running it with the 255's???
I'm thinking I could put the money from the lift into sliders instead.
Thoughts?
Thoughts?
You didn't like your stock Pro tires? The 255's is only about .5 bigger.
Sent from my SM-G930V using Tapatalk
Not really. The Terra Grappler AT in a P didn't really fit my needs. Went out in like 4" of snow a few times and almost got stuck going up a fairly easy hill.
They're great in town but for playing off road and with my hunting and fishing habits I really wanted an LT tire that was a bit more aggressive for year around.
But ya size wise there's barely a difference. Was on the fence with 255/80/17 ST Maxx but I've ran the Pro's before and really liked them.
285s
Here is the 285 ridge grapplers with ~3" front ~2" rear. Performed great on the trails.
Thanks
I had a customer that was in your exact situation. He wanted to fit 285/70r17 tires but did not want to just trash the TRD Pro suspension. He ended up going with a Icon front leveling spacer up front PT#IVD4100SD this part bolts on top of the factory upper strut mount, and a ToyTec 1.5" rear spring spacer. He now has plenty of room for 285/70r17
This is what I was looking for!
ReadyLIFT 3/2 with 275/70R17 BFG KO2's looking to go 285/70R17 Cooper STT Pro or Nitto Ridge Grapplers. Any feed back on these tires would be great.
