Raycie's Trail Build
raycie
Finally get to do a build page.....
2016 T4R Trail Premium w/KDSS
Suspension:
- (OME) 884 Front / 3" Rear
- Camburg balljoint UCAs
- Wheelers front bumps
Wheels:
-Black TRD PRO Rims
- 275/70/17 KO2s
Armour / Etc:
- Pelfreybuilt Sliders
- ARB KDSS Skids
- Extended FrontRunner Roof Rack
- ARB 6x8 canopy
Electrical:
- Heretic studios 20" flood (grill)
- Rigid Srq Diffused (backup)
- Rigid Srq flood (hood ditch)
- Rigid DOT floods (just needs to be installed)
- ARB Twin Compressor (@bandi mount - [MENTION=123342]BOSS4x4[/MENTION])
- Blue Sea fuse and breaker (custom mounting plate)
- AOB push button switches
- LED interior lights
Misc:
- Cargo Tray
- Toyota Bug Deflector
- Tint
- Weathertech digi-fit
- Weathertech Window Deflectors
- PRO Front Garnish
- Rear camera dongle
- Front camera and switch
- Custom cooler slide
Upcoming:
- 2nd front camera
Recently sold my "Built" 2007 Toyota Tacoma DCLB Prerunner. Swapped out the LSD with a ARB rear locker, had a 3" lift, sliders, aluminum pelfreybilt front bumper, Frontrunner Rack, and a couple Rigid LEDs..
Only went offroad 5% of the time, and only 1% of that time, I needed 4x4. I had the opportunity of get a 4R at a small discount, so with the Boss's approval, I went with it.
Here is the truck:
Picked up the 4R today (10/31/15)... bought the PRO rims from the dealer, and had them swap right away. Next up was a tire swap over to the 275/70/17 KO2s.
Off the Boat:
With Rims and ready to go home:
Old tires:
New 275 KO2s:
Tires On:
Just Tinted:
I do like the front grill of the T4R PRO.. Some $$, but I like it a lot..
Since the cover went on, I thought I may as well try and spray the lower piece. I tried the first time to dip it on the truck, but the line came off bad... I decided to take the piece off, and dip it separate.. Did the rear as well..
The the Front Runner Roof rack came in. I did get the 8" extended version. It covers the sun roof by a bit, so the wind deflector needed to go on the 2nd plank rather than the front one.. Have a little bit of rattle coming from the sun roof... Have some rubber stripping coming from Front Runner to see if that cures it.. Other wise, I'll try and move the deflector to the front and see if that makes a difference. No rattle when the moon roof is even cracked.. I think it is the wind hitting the rack, then bouncing off the glass.. Will update as I do some R&D... If you don't have the sunroof, you would have ZERO problems with the extended version.
Also added a custom TRD Trail Edition sticker... (adds 10HP)
Blue sea fuse box install:
I guess I'm glad I started a build thread, cause didn't for the Tacoma and wish I remembered what it looked like stock.. lol..
Rcok Sliders
Glad to see you have plans to ditch those running boards and install rock sliders. Those running boards are damage enhancers.
Where did you find the TRD Trail Edition sticker? My TE has no badging to indicate it's the TE.
A friend of mine made them custom... he will do them for $10 for 3. I'll get a close-up pic uploaded...
Had a friend make me a custom bracket for a blue sea fuse and a bussman breaker. Compressor is in the main, and some rigids will be added soon..
Current:
- Black TRD PRO Rims
- 275/70/17 KO2s
- Cargo Tray
- Tint
Future Mods:
- ARB Twin Compressor (incoming)
- Blue Sea fuse and breaker (incoming)
- Weathertech Window Deflectors (incoming)
- Pelfreybuilt Sliders (incoming)
- Suspension (Icon Stage 2 or OME BP-51)
Off the Boat:
Old tires:
New 275 KO2s:
Tires On:
Just Tinted:
did you make that bracket for the fuse box urself or did you order it?
Yea.. had a friend make me the fuse bracket.. I'll take some better pictures over the thanksgiving weekend. Has a bracket on the bottom, and a plate on top which screws unto the bracket. I got my power wires and terminals, just waiting for the crimper and the shrink then I'll connect it up.
At first, I was going to run the ARB twin off of it.... until I realized that it is gonna run like a 60A fuse.. lol... will probably connect it to the back side of the breaker for a little protection.....
maybe your buddy can make a few to sell to people on the forum... just a thought.
Possibly... I'll ask him...
Well ARB Twin came in last night... that thing is a whopper (just under 20lbs).. I need to grab some terminal rings later today. All the other stuff (4 gal crimper / heat shrink) will come in the mail tomorrow night.
Guess my Thanksgiving, and black friday will be fun...
Sliders and Weathertech window deflectors come next week and getting installed the following weekend.. then slowing down... Just gotta save save up for the lift...
Where are u mounting the compressor?
Sorry.. Been MIA for a bit... compressor was mounted on the passengers side with the [MENTION=125603]bandi[/MENTION] mount.. used some switches from AOB (push button) and have the compressor switch on the driver's left knee..
Doing a camping outing this Saturday. Will post up some more pics, but compressor is installed, Pelfreybilt sliders, and some getto plasti-dip just in case for some =branches..
