Rhino Rack on TRD
simonsay
So I wasn't sure I wanted the gobi or baja for a number of reasons.
1st off, everyone and there mother has them.
2nd, both are HEAVY and since I use mine as a daily driver, why not find something lighter?
3rd, I don't use the top as much as others. A shovel, hijack, and a set of TREDs (which currently are on kickstarter for 50% off!!!!).. Maybe one day I'll stick a tent up there....maybe (my wife hates camping. If there's not a hotel nearby at the end of the day, we aren't going in that direction :der:).
Anyways, here is it. Installation was pretty easy and it fits like a glove. Aluminum means light weight, quality product that should last a long time.
I searched and could not find another 4Runnner with it... Anyone else have one installed?
Love the rack! It looks really clean. How much load weight/ static weight can it handle?
Thanks for the KickStarter heads up by the way! Such an amazing deal!
How much and where did you get it?
Jon
The cost on their website is more than authorized dealers. They want you to buy from them. I got mine from rackoutfitters.com out of austin, texas with free shipping.
It's aussie made, so it's not cheap. $629 for the rack and another $170 for the SX clamps to attach to your rails.
It's the rating of the original rails which is 300 lbs dynamic or 600 static if I recall (less the weight of the rack)
Here's a pic with a hi-lift attached... it's photoshopped, so the size may be off by a little. Only thing I was debating is if I should paint those rails black instead of that silver.
And here are the rails photoshopped black....hmmm... I may have to take the rack back off...
The rack looks really good. It looks like a good alternative for the clearance I require. Thanks for posting.
What is your lift and tire setup?
Tires are the stocks on the TRD. Once they are ready to be replaced, I'll probably go with 285's.
The lift I just got is a 2" specifically for the TRD. You can read the thread here if you have a trd and are interested in giving it a little height:
http://www.toyota-4runner.org/5th-gen-t4rs/208900-trd-pro-lift-question.html
You might want to look at the front runner racks as they are at the same price point and have a ton of accessories. I'm guessing it also sits lower.
Rhino Rack is good stuff that doesn't get the love it deserves is a market dominated by Yakima and Thule. And, if I recall, Rack Outfitters is likely the cheapest place you'll find any of their stuff due to pricing restrictions.
PS - I just painted my roof rack black. It looks better.
I did some looking around there too. There were a few things that got me to so no.
#1. You'd have to replace the rails with their rail which I didn't think looks as good.
#2. It doesn't sit lower (I actually think it sits a little higher). I believe the frontrunner sits 5.1 inches from roof. The Rhino is at 4.5 (maybe someone can verify that).
#3. Weighs more and costs more. 50lbs for the rhino compared to 80lbs from frontrunner. And cost is $927 for the frontrunner compared to $799 for the rhino (rack and rail mounts).
From the look of the accessories stand point, both have good options. And by looking at how they hood up, it could be that some can be used for either system.
#1. Some may think it's looks better and may not want to have to paint their existing rails black for a cohesive look. To each their own.
#2. That's surprising that the rhino is lower. Possibly the front runner needs a little extra clearance for the table to slide under.
#3. The rhino rack, cross bars and OEM rails only weigh 50lbs?
I would still consider that the pricing is in the same ball park.
#4. The front runner is available in 3 lengths and can be upgraded if needed.
On the weight I think you need to subtract the weight of the existing rails that are removed for the install of the front runner. It is still probably heavier but it may be little enough to be negligible.
My front runner sits at 5.5“ so it is taller. Very surprising to see something slimmer than the front runner.
I would have seriously considered the rhino if I had known about it. My front runner is longer than the standard 4runner version though and I paid $998.00 shipped. Really happy so far but I haven't had it for that long. It would be interesting to complain both racks side by side. Looks great on your rig.
The rack itself is 43lbs, and the mounts might a few pounds each.
Rhino comes in at 60 inches long compared to 61. I think the weight comes in with those rails.
My mistake on the height of the frontrunner. I think it's higher, but not sure if it's more than 5 inches from roofline...someone else can verify if they have one.
5.5 on the frontrunner to 4.5 on the rhino... case closed on that one.
Yes, thought about that too. Not sure how much the factory rails weigh.
The factory roof rails don't weigh much but they do flex! This is why almost all roof racks replace the factory rails.
It's a shame that wouldn't fit on my Trail. Guess I'll just have to make do with my "heavy" old dime a dozen Baja Rack..... :pout:
