Old 12-17-2015, 07:58 PM #1
RysiuM's Avatar
RysiuM RysiuM is offline
RysiuM is on a distinguished road
RysiuM's Avatar
Which LED or HID work and don't work in 2010-2013 low beam reflector type headlights
There was a thread (unfortunately deleted by OP probably) about installation of LED IMPORT USA bulbs as low beam in 2012 4Runner. I had to disagree with OP who recommended these bulbs. From the pictures "before" and "after" we could easy that after installing these bulbs low beam lost the cut off and obviously would blind other drivers. It's a pity the OP removed all pictures (very valuable for comparison) leaving only two (see below) showing clearly the main flaw in Led bulb application. Looking at the photos you can see that LED bulbs do not produce cut off like halogen bulbs do, what means these LED lights will be blinding not only the drivers on the oncoming traffic but also the guy in front (the dimming mirror will not help this poor guy).
In my research I found that there are two issues related to LED chips vs halogen filament that might screw up the projection. Both are related to the fact that the light source (filament) in standard halogen bulb is exactly at the center of the bulb and has 360 degree even projection to the side.
1. Led chips are usually located on both sides of flat mounting blade, so the light source will never be exactly at the center of the bulb. So there are two light sources a little bit off the center of the bulb. The low beam projection cut-off may be screwed up by that.
2. Each chips have roughly 120 degree projection angle (lambertian), so there is almost no light in the surface extending the "blade". This can create "black spots" in the projection.
While some projector type housings are not sensitive to these problems, all reflection type housings I heard of don't work correctly with LED bulbs on low beam.
So I'm calling all you guys who had experience with LED or HID bulbs installed in 2010-2013 4Runner low beam headlights. Show me your projection, if the cut-off is there (or maybe better), and the lighting area is even or better than the stock halogen bulbs. I am looking only for 2010-1013 reflector type headlights, not 2014+ projectors. For the reference here is the cut-off line from stock halogen bulbs.
An for the first there is a comparison photo of LED IMPORT USA bulbs (from the thread deleted by OP)
Which LED or HID work and don't work in 2010-2013 reflector type headlights-stock-vs-led-import-usa-jpg
RysiuM is offline   Reply With QuoteReply With Quote
Old 12-17-2015, 08:16 PM #2
FrontRange4Runner's Avatar
FrontRange4Runner FrontRange4Runner is offline
Real Name: Tom
FrontRange4Runner is on a distinguished road
Real Name: Tom
I was just looking for that thread, as I wanted to pick up those reverse lights he posted. I think I fond them so no worries on that.
This topic comes up a bunch.....It seems like all of the guys who are lighting nerds (ie, know way more than I do on the subject) say the same thing. LED's and HID's are meant for projector housings, which us 5.0 guys don't have and even the 5.5 guys have projectors designed for halogens. I have yet so see pics of an aftermarket HID or LED installed where there was a good cutoff from the stock housings in a 5.0. They were designed specifically for the halogen bulbs and nothong else. The easiest and cheapest light upgrade for us is explained in this thread. I have done it my self and for the price and work level involved, it is awesome. A ton more usable lights, and no crazy glare. Otherwise, you need to get a quality aftermarket conversion.
2012 Trail (KDSS), Falken Wildpeak AT3W (E) / General AltiMAX Artic's, Level 8 MK6 (0), Pilot stubby, Max Liners
FrontRange4Runner is offline   Reply With QuoteReply With Quote
Old 12-17-2015, 08:27 PM #3
MTN4RNR's Avatar
MTN4RNR MTN4RNR is offline
Real Name: Max
MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough
MTN4RNR's Avatar
Real Name: Max
Reverse light info can be found here... Same ones he used...
Building, Driving and Adventuring the MTN4RNR
2016 MGM Trail Premium - KDSS
Explore4R.com
Building the MTN4RNR
Instagram --- life.to.the.max
Writer/Editor at Trail4Runner.com
MTN4RNR is offline   Reply With QuoteReply With Quote
Old 12-17-2015, 08:34 PM #4
Real Name: Tom
Real Name: Tom
Thanks man! Looks like I got the correct ones.
Old 12-17-2015, 08:52 PM #5
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
I'm not a 5g owner but lighting has been a hobby of mine since I bought a HID kit back in 2000 for my Tundra. I'm currently experimenting with a LED conversion for reflector headlights.
@RysiuM when looking directly at the headlights (might want to wear sunglasses or a welding helmet to dim the light) what areas of the reflector are illuminated? Is it basically the upper half and a "pie cut" from the center of the circle to about 4 o'clock?
And yes the 921 LEDs in the deleted thread are Philips Visions. I use them for my 3rd-gen 4Runner front parking lights and our 1st-gen Tundra reverse lights. Unfortunately due to the smaller reflector/lens on my 4Runner the 921 LEDs in reverse lights didn't make an improvement but work great on the Tundra. $19.99 @ Pep Boys but if ordered online for store pickup they're $13.99.
Old 12-17-2015, 09:09 PM #6
blakjack23's Avatar
blakjack23 blakjack23 is offline
blakjack23 is on a distinguished road
blakjack23's Avatar
There are some custom made t4r 5.0 projectors on ebay right now......for $790.
blakjack23 is offline   Reply With QuoteReply With Quote
Old 12-17-2015, 09:51 PM #7
RysiuM's Avatar
RysiuM's Avatar
This is stupid for T4Forum to allow delete the entire topic with all posts written by other members then OP. So much good information was lost with one click of the button. If I was OP and I did not like what I wrote, I would correct my own posts, not delete other people's writing. Good thing was that my browser captured most of the thread in the cache so I did not loose everything I wrote.
So on the topic of Philips LED Backup I bought the other bulb recommended on this topic. For $6.83 I bought "2X Error Free T15/T10 High Power 15W LED Backup Reverse High Stop Light 921 912" on ebay for testing, as they were claimed to be real hot topic:
The eBay bulbs measured at .899A @ 13.14V or 11.81W, 1417lm using the 120lm/W. I also checked the Philips bulbs since I have a set and they are .241A @ 13.14V or 3.17W, 380lm. You are right that the eBay bulbs are overstated, but still significantly higher wattage and lm output than the Philips.
My experience with these bulbs is quite different. As I expected, they are way overrated and the description is total BS. At least comparing to what I got.
The bulbs I got take 0.3A each at 12W (measured), what puts them into 3.6W, less than 1/4 of claimed power. They have MB6F bridge rectifier (reverse polarity protection) which has 1V voltage drop (per datasheet), so really it is only 11V delivered to LED driver (4211 buck type constant current Led Driver). Led driver is very efficient (about 92% efficiency per datasheet). So from simple calculation 11V*0.3A*0.92 = 3.036W - that is the power that actually goes to LED chips. Assuming 120lm/W the bulb will give about 365 lumens, not even close to 825-900 lumens as they claim in the ebay auction description.
So I am disappointed with the result, but I would lie if I say I wasn't expecting that. Anyway I gave the chance to ebay seller to comment on that, maybe he sent me the wrong item (the driver on ebay item pictures looks a bit different from what I have). I'm waiting for his response.
Now back to low beam topic, I am aware of H11 to H9 conversion, which gives extra 700+ lumens at the cost of 10W and half of the lifespan. I also know about converting headlights to projection style by some hacking and inserting projector unit. This is not what this thread I like to be about. It may actually die fast with just one sentence: "There is no LED or HID solution available", but then I would like you guys also to share your negative experience, for others "How to not do it". It may save some guys from potential modification in the bad way.
Old 12-17-2015, 10:15 PM #8
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
C'mon, you know as well as I that he deleted that because he got a lot of criticism. Perhaps he did the smart thing, before it descended further.
As to resurrecting the topic of using reflectors with other-than-halogen bulbs .......
Which LED or HID work and don't work in 2010-2013 reflector type headlights-img_0015_1-jpg
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 12-17-2015, 10:21 PM #9
RysiuM's Avatar
RysiuM's Avatar
From your signature I guess it is "HID LS460-R @ 55w projector retrofit". Right?
Old 12-17-2015, 10:25 PM #10
Hellamatic's Avatar
Hellamatic Hellamatic is offline
Hellamatic is on a distinguished road
Hellamatic's Avatar
Plain and simple, if you run LEDs or HIDs with anything other than a proper projector retrofit, you will be forever referred to as "that dickhead with the blinding lights."
2012 4Runner Trail Edition....None more black
Hellamatic - Build Thread
Hellamatic is offline   Reply With QuoteReply With Quote
Old 12-17-2015, 10:29 PM #11
philsey's Avatar
philsey's Avatar
Huh?
Old 12-18-2015, 01:32 AM #12
Real Name: Tom
Real Name: Tom
My experience with these bulbs is quite different....So I am disappointed with the result...
Bummer, Hopefully I am happy with the result. It's a bummer that the thread was deleted because there was definitely some good info in there. I may have made a slightly dickheadish comment in that thread at some point last night, so if I did, my apologizes to @rigtec . Beer and bad lighting cutoff makes me angry apparently.
As to your original question, There is no proper, plug and play LED or HID solution available. If there were, these lighting threads would end much differently than they do now. Unfortunately, if you want a high quality lighting solution, you have to pay the big bucks for it.
Old 12-18-2015, 02:31 AM #13
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
I'm not really a fan of that, it's a public forum.
I hate when I miss controversy.
To the OP, I ran H9's for awhile, took them out when I lifted my truck, just didn't want to be a jerk. As it is I get blinded fairly often from folks with aftermarket HID lighting. Heck I've even had a 14+ Trail behind me with HID in his projector, it freaking sucked! There are plenty of folks that don't care I guess, I never try to flash these people but based on how many people comment "never been flashed" maybe I should.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 12-18-2015, 02:42 AM #14
RysiuM's Avatar
RysiuM's Avatar
There is on positive thing in 4R low beam - it has one way bulb (one filament per bulb, unlike for example H4 that has to deal with two light sources.
Because in low beam we may use only the top part of reflector (to shine down) it will be enough to have a LED chip on one side of the "blade". Now if that blade is asymmetrical such as the LED chip is exactly at the center of the housing (exactly where the original halogen filament would be) such bulb has a chance to produce usable cut off. Because as soon as the second LED chip is introduced on the other side of the blade, the cut off is screwed up big time.
Good quality HID bulbs has also good chance to replace halogen H9 for low beam. But it has to be really good, high precision bulb, not China knock-off. Still yet to discover.
I saw that - very custom job. Of course doable by using projection unit (available for 200-300 bucks per pair) and some custom engineering. The total cost looks about right too ($300 for projectors + $200+ for stock lamps + labor and engineering), but I'm still looking for possible lower cost retrofit. Saying that, by lower cost I don't mean to compromising the cut-off or introducing "dark spots".
Huh?
I'm sorry - I saw the picture
and assumed it was taken from the truck described in your signature (BTW I would love to have such cut-off in my 2012 SR5). BTW after reading the "deleted" thread I don't think the subject is "dead horse". There are still many T4R owners, who require education on the lighting "the proper way".
Old 12-18-2015, 09:29 AM #15
philsey's Avatar
philsey's Avatar
I'm sorry - I saw the picture and assumed it was taken from the truck described in your signature (BTW I would love to have such cut-off in my 2012 SR5).
Well, yes and no. Right truck, previous retrofit (FX-Rs). Poor picture but I felt the need to show what properly retrofitted headlights look like. It's not all about the cutoff either; the beautiful clean light and the terrific spread too. The LS's are even better, but I spent a $hit-ton to get from 9/10 to 10/10.
Perhaps. I just felt that by now we should have realized that reflectors don't work properly with any light source other than a halogen bulb.
2007 4runner lights, horn and blinkers work, but hazard will not work rki1966 4th Gen T4Rs 1 09-21-2014 02:08 PM
2013 SR5 level and 33" tires - will it work? Tylerdh 5th gen T4Rs 30 10-18-2013 03:25 PM
2013 FJ cruiser suspension work on an '04 4R? Cory619 4th Gen T4Rs 1 10-05-2013 07:32 PM
Will 2013 FJ Offroad Suspension work in 99 4-runner? grifterec 3rd gen T4Rs 11 08-26-2013 03:04 PM
Will these headlights work/any pros-cons? Jon 3rd gen T4Rs 5 10-20-2010 05:23 PM
