"Upgrading your console interior map lights with 'Philips 194 LED's!'"
Hi team,
I'll be installing these leds today:
They're the: Philips 194 LED
I wanted to repost this 'pictorial essay' which I felt had benefit, but accidently got deleted along with another thread that I took down... hope I can remember what I said in that post... :noidea:
"THE BEFORE"
rigtec-albums-riggy-s+workbench-picture37319-20151211-145820.jpg~original
To begin, insert a small (electronics type) flat-head screwdriver here as shown in the photo below; remember that patience is your very best friend so 'take your time':
SCREWDRIVER INSERTION POINT
rigtec-albums-riggy-s+workbench-picture37320-20151211-150033.jpg~original
I'm deliberately targeting the lens at it's hinged anchors (there are two). Once they let go, nothing else holds it in place!
AND HERE ARE THOSE HINGES; "just for your reference"
rigtec-albums-riggy-s+workbench-picture37321-20151211-150159.jpg~original
Great!
What bulb did you use for the back seat, above head? You want the light color(s) to match on the interior.
Thanks in advance.
Great! What bulb did you use for the back seat, above head? You want the light color(s) to match on the interior.
Thanks in advance.
Hi Cobalt,
I haven't replaced the dome light bulb as of yet. The reason that I changed the 'map-lights' was simply because they were incapable of providing light adequate enough to read a map; or anything else for that matter! I do like that white light color that these 'Philips 194 led' bulbs dish out... just not sure if I want to change the second row 'Soft lighting' atmosphere/privacy at this point... guess time will tell!
cheers
Hi team,
"THE BEFORE"
Great!
Thanks in advance.
I believe the doors and map light are 194. The dome and cargo area are 3022. No idea on the backup lights.
Hi Cobalt,
cheers
Gotcha.
I installed an LED in the back seat of the 4Runner but it was dimmer than the factory light so I returned it. I wasnt fond of the front and rear light sources not being a color match. It looked like an accident. Now if they were colored, that would be different. Your point is however well taken. I installed all blue lights inside of my Maxima for privacy & mood. The exterior paint color was cobalt blue as well. #Uniformity #Cohesive #Custom
P.S. I need to find out what the Phillips equivalent LED is for the backseat for future reference.
I personally just put in an order through SuperBrightLEDs for all interior and exterior (side mirrors, reverse and license plate) lights. It was an easy one stop shop. Cost $163.00, but everything is color matched and uniform. Cant wait to do the swap.
Did that price include anti-flicker devices?
Hey guys,
I got map, dome, tail gate, license plate, courtesy, and puddle lights all for $75 at Car LED Lights - Interior LED Lights For Cars .
I'll post a picture when I install them. It also comes with two free tools to help you with the plastic removal and a youtube video with step by step instructions.
I used the code youtube11 to get a percentage off the total. Can't remember how much it was off, but it covered shipping.
Here is the video link if you want to check it out
https://www.youtube.com/watch?v=6O30-rctTDA
I just replaced all of the interior lights with Philips LEDs. The dome light is in fact a different bulb. I had trouble fitting a 3022 bulb in that location as it's a bit too long.
Also, the Philips is a different temp. If the 194 bulbs are 6000k, the 3022 bulbs are 6500k+. It's noticeably more purple.
I'm very disappointed with the end result, other than the map lights.
Here you go, these are 6000K and will match 194's.......Amazon.com: Philips 30mm festoon Bright White Interior Vision LED light (Pack of 1): Automotive
If you really want more output/brighter, check these out......... 6K WHITE 6 LED HIGH OUTPUT DOME LIGHT BULB 31MM 3175 DE3175 170LM - 3175 31MM LED - Shop Bulb #
Thank you, but those are the lights I'm referring to.
They have some others that are called Extreme Vision, but I'm still unsure of color and brightness.
Amazon.com: Philips 30mm festoon X-tremeVision LED 6000K Interior light (Pack of 1): Automotive
Phillips doesn't list lm output......not sure why, but this is what they list for specs X-tremeVision LED LED car light 129416000KX1 | Philips
Output (compared to link I provided) should produce a brighter light since its not defused. Color should be the same since it's rated at 6000K.
This thread was a great help in doing my own interior LED conversion!
However, I found that the Philips 30mm Festoon listed here was actually DIMMER than the 2 year old factory bulb!
In place of that I'd suggest this JDM ASTAR DE3175. It is a little over-sized because it's a 31mm instead of 30mm, but a small bend of the flexible retainer and it fits and holds fine. For ease of install, bend the retaining clip before you try and shove the bulb in there. Because both the dome and liftgate lights lack a reflector behind the bulb, this should work better with all 6 LED's on the same side.
After having issued with the dome light I also ordered a couple of JDM ASTAR 194's to test. They are much brighter than the Philips 194's. While they are an exposed circuit board, the bulbs are housed very well anyway. Hence I returned all of the Philips LEDs and used the JDM ASTARs to do the whole truck. I forgot about the puddle lights and have to go back and do them now, but here's how it looked getting into the truck last night.
I'm not 100% sure, but I think my interior car lights dim down for a couple of seconds before turning off rather than turning off instantly; led's don't like potentiometers. You may want to consider turning this feature off if that's a dealer serviceable option.
