Does anybody use Carista?
AudiTech
Carista OBD2 - Vehicle Diagnostics and Customization | Your car, your way
I searched the name, it popped up with a couple mentions but not much. Does anyone have any experience with this? I'm wondering how useful it really is. I'd be interested in hearing first hand experience about which modules can be accessed and how much in the way of coding and adaptions it will actually let you do.
$40 for the dongle and $20 for the software seems like a good deal if it's really comparable to Techstream but without the hassle of the knock off compatibility problems.
your best bet is probably to look thru the club lexus forums. a lot of them over there use it and from I remember the techs from the app are over in the forums a lot more than here.
good luck.
Already had the dongle for Torque, so I got Carista, used it to set a few parameters, satisfied with it.
I just received the carista module today and have only started to use the paid app for it but so far so good. I just turned off my seatbelt chime and took a few screenshots of other options you can change.
I haven't confirmed it yet but it looks it does. Check their site to make sure it's compatible with the make you are trying to use it for but I would assume you get the full rights to the software in the app.
The Carista app does not seem to do much in regards to monitoring vehicle stats so I plan to buy OBD fusion ($10) for that.
I got that app a while ago, it was only a one time purchase not a subscription. Some of the options I tried setting didn't seem to take effect, but some of the other options did. It lets you change settings on various vehicles, some makes/models allow you to do more changes than others.
As for the code scanning feature, it also lets you read the ABS codes too. (Helpful if you're getting dash lights right after a lift installation.) The other apps I tried wouldn't read those codes.
Does it let you disable the stupid seatbelt chime? That is all I really care about. The rest is icing on the cake. Stupid dealers will not change the setting, claiming legal liability. I'm an adult and an American, I dont need or want the govt telling me how I should be reminded to put my belt on, or much else for that matter.
did you even look at the pictures posted...?
I did. That was followed by the comment that some settings took and others didnt. I wanted to know if the seatbelt chime was one that actually worked.
I'm interested in this also. Particularly, I want to know if the "Windows and Sunroof open" option works if you hold the unlock button. Had that in an Acura and thought it was cool.
So I have confirmed the seatbelt chime is off. The wife swore I was trying to kill her when I told her to take off her seatbelt while we were driving in a parking lot so I hope you are all happy. I'm gonna try the Windows tomorrow and report back.
So I got it all working. Windows down with remote long press and windows up and down with the key in the door. I don't have a sunroof so I can't comment about that but pretty safe bet they are all tied to the same system so it should work.
All functions work in Carista, so if you see it, they should work, so long as you have that option (such as having a sunroof, etc).
The good:
Easier to use than the techstream, seeing that you don't have to deal with having a pc.
Android ties into cheap ELM327 with this app, so cost is relatively cheap.
Reads and erases all codes, including some that don't show up in other apps (such as torque).
The bad:
App is incredibly slow to connect! Timed at 3:46 to initially connect.
App will NOT stay connected to obd2 adapter. You have to pull it, plug it back in, then wait for security code to come up before it will connect and set your parameters.
Reads codes extremely slow! 4:24 to reach 100%. To erase codes, click erase, then pull adapter, then plug back in, then enter security code from adapter (1234), then it will erase. Same process for each and every setting, unless you set them within 10 seconds of the last setting, so it disconnects within 10 seconds from the adapter.
While its not overly expensive, its not an app that you will use on a regular basis. It doesn't monitor any of the vehicle's information, aside from overheating (which I did not confirm whether its working).
I think its a bit overpriced for what it does, but there's nothing for the android that I know of that does the same thing, and its nice to be able to change something when you're on the road and without a pc and the TIS cable/software.
Personally, I think its better to just get the TIS cable/software, for the money you spend going that route, you at least get to program keys and do a lot more than Carista.
Just my own opinion though, maybe other adapters work better than mine, I'm still using the see-thru blue ELM327, ver. 1.5, adapter.
Ah the ever-so-elusive "Interior Footlight"
So far I have only found one car in Toyota's lineup that has that option... a Rav4 (LC must have it too)
The problem I have with the techstream software is I use all apple products and don't have access to an old laptop running windows xp just for this purpose. To me, that is the appeal of the carista.
The Windows down feature with the unlock and lock buttons.....
Is that only with the smart remote or does this work for the regular remote as well?
It works on the standard remote, I have it working on my SR5 model. Just wish you could put it up too, but that's not an option, aside from putting the key in the driver's door lock and holding it.
