Hook Em Horns! Build Thread
Hook 'Em Horns!
I did things backwards, and posted a bunch of mods here and there. Now I am starting a build thread so I can easily keep up..
Installed TRD Pro grille
TIS Techstream Mods
TIS Techstream Mods
Disabled:
•Seatbelt ding
•All doors unlock when put into Park
•Lock/Unlock chirp (lights still flash)
Enabled:
•Hold down Unlock on key fob = All windows + moon roof open
•Turn key left/right in driver's door = Rolls windows + moon roof up/down
•Extended side mirror ground lights time to 30 seconds when pressing unlock
LED Light Swap (Interior/Doors/Reverse/Side Mirror Puddles/Plate)
Easily swapped out with the $20 kit from eBay
'13 TE Door Handles
I decided against dip, and went the extra mile to make it legit. I ordered '13 Trail Edition door handles/bezels, and installed them by following the instructions below:
Taking Off the Door Panels:
http://www.toyota-4runner.org/5th-g...92s-ideas-since-mid-2010-a-26.html#post774421
Door Handle Changeout:
http://www.toyota-4runner.org/5th-g...92s-ideas-since-mid-2010-a-27.html#post775510
Thanks to [MENTION=48991]sp8ball[/MENTION] & [MENTION=65614]Antman[/MENTION] for laying the tracks!!
Toyota Online Parts | toyotaonlineparts.com | OEM Toyota Parts
How did the install go? I have a set of oem painted ones to go on that I've been putting off.
It went surprisingly well. Took me about 35 mins per door, but I was also doing my "I'm working in the garage" drill (drink/smoke) :)
You shouldn't have any hiccups provided you follow the mentioned threads. The torq screw on the the inside of the back seat doors was out of reach, so I can say you'll need an extention piece for your torq screwdriver. Let me know if you have any questions once you start.
\m/
\m/
Awesome. Thanks man!
Paid In Full!!
PAID HER OFF TODAY!!
"You should receive the title in 10-15 business days"
That's MY truck!! (in Debo's voice) :banana:
\m/
Tires: What should I do?
So I ordered the black TRD rims and now trying to decide on which tires & size to go with, and looking for honest advice/opinions.
I want an aggressive tire that:
a) fills more of the wheel wells
b) gives a nod to/focus on mud handling
I encounter plenty of random THICK mud patches at my parents ranch, and while my stock tires worked the first 12K miles, now they just cake up the mud and look like slicks when I'm in the thickness and I keep getting stuck accessing those areas of the property and sliding down the creek bed due to zero traction. My pops already had to pull me out twice.
So far I have narrowed it down to a few finalists based on reviews focusing on/off-road performance, reliability, lifespan (relative) and aggressiveness:
•Cooper STT Pro (in either 265/70/17 or 285/70/17)
--E Load Range
--Superb mud tire
--Can handle any terrain
--Best reviewed MT tire for on-road noise level (quieter than the Nitto!) and performance/handling
--Great on wet surfaces
•Cooper Discoverer STT MAXX (in either 275/70/17 or 285/70/17)
--E Load Range
--Mediocre mud handling, but reviewed as better with mud than K02s
--Great on-road performance/handling...Even in wet conditions, which the K02s aren't being well reviewed in that category at all
**Note: I didn't list any other MT options other than the STT Pro, as its the newest, highest reviewed and quietest one on the road I've found reviewed thus far.
Factors:
•I have a 3front-1rear RevTek spacer lift (for now), and 4WP said it will "comfortably fit 33"s, and will fit 34" tires with slight shifting of liner"
•TRD wheels are 7" wide (285s recommend 7.5+). I know there's PLENTY of discussions on here, and PLENTY that say it's fine to throw 285s on the TRD wheels, but I've also been told to expect sub-performance, added wear on drivetrain components, and accelerated tire wear, and UCAs rubbing??
•I don't care about gas mileage, as prices are only gonna go down
•Should the KO2 be on my list? Are they good with mud or not? Too many conflicting reviews on these. I'm just not sure if the negative reviews are due to bad initial batches/shipments (even had recalls), or if there's a larger issue with the tire designs in general. Specifically the wide-ranged balancing issues and the weird wobble at 55-65 mph others have mentioned after repeatedly rebalancing.
Either way, the K02s don't perform better in mud than the ST MAXX, at least from what I've been reading.
Ultimately I really want the STT PROs, and guess I can accept staying with stock size (265) for now and grab the STT Pros (E range), but want to ensure my reasoning for doing so is sound.
I've read a ton of STT Pro reviews state the tires are actually smaller than the advertised measurements, and I'm starting to wonder if I can fit 285s with a RevTek lift and do so safely with the 7" TRD wheel..
So yeah, crazy long post, but this is what has been on my mind for the last week lol
If it were you, which direction would you take and why?
Is the 7.5" width recommendation for the 285s a safety concern or just tread wear concern? (We have a 9 month old and another in the oven..)
Anything better than the STT PRO??
Thanks in advance for opinions/advice!
I'm still a little green, so take it easy on me @ST1FLER
Heck, @marshal - What's your take on this one, Pór favor!
\m/
.<!-- google_ad_section_end -->
I've been doing alot of reading here to answer most of my questions and alot of your questions seem very similar to mine. I too have just got the TRD rims yesterday and will be putting on 275 Ko2 on them tomorrow. I have a set Ko2 on my truck and they have performed well so far on street and for me on sand as i have used them on the coast to lug my kayak around to fish. 275 seems to be the safest bet with minimal to no rubbing and you will get that aggressive look indeed. I also read a high amount of post with 285 rubbing but most folks who were getting those were eventually going to do a lift soon. IMO id stick with 275 or 265 since you won't be touching suspension for awhile. Guess it will depend on what driving you do most but sounds like ALL terrain may be your answer.
if you want, i can post a pic here of my truck when i get them mounted tomorrow. i have a 16 TEP in Super White.
