2010-2015 TRD CAI intake question
NEExpo
So I'm looking for someone who has the 2010-2015 TRD cold air intake installed on their 4Runner. I need to get a measurement off of it if you don't mind undoing the hose clamp at the air box and giving me the tube diameter of the box. Included is a photo of the CAI and I have an arrow pointed to the spot I need measured. I have an idea up my sleeve but before I spend the money on it, I want to know if it'll work or not. Thanks!
Since you didn't post your ideas, I'm going to just guess what you want to do. Stock box and TRD box parts are not interchangeable. There is actually a thread somewhere here that talks about the diameter of that section.
Exactly what I was wanting to see. If the TRD intake pipe and hose couplings would work with the stock box lid. I didn't want to say anything about it and get people's hopes up on a cheaper alternative lol. Just needed a size lol. Oh well. Thanks for the info [MENTION=106054]rydr1[/MENTION]
There is a guy here that pieced all the parts together and if I remember correctly paid under $300 for the whole set up. The thread is here somewhere and the guys were cool enough to put links and part numbers needed.
Post 161 and 162 says he only paid $216 HERE
http://www.toyota-4runner.org/5th-gen-t4rs/191035-crawford-eco-block-16.html#post1952779
Reading that post I think it is 4.125 ID (and I measured with a tape), but I don't know if you want an OD or an ID.
Somewhere on this forum somebody did a before and after dyno test.
As I recall it was an increase in hp, I think 5, don't hold me to it.
Horsepower was minimal like you said but I believe that torque was about 19 lb ft. I'm going to order the individual parts and get this moving.
I have the K&N and couldn't be happier. I looked for a TRD for the 4Runner and couldn't find one
I don't like the K&N CAI what so ever. The open box design is poor for what I plan to do with the 4Runner in the future. A closed box intake like the stock or TRD CAI is what I need for later down the road when I finally pull the trigger on a snorkel. Not too worried about horsepower gains. Just wanted to create an unrestricted air flow by mating the TRD CAI intake pipe to the stock box lid. I already have an AFE Pro Dry S filter in the stock box. Just by swapping to that I felt a little more pep and less restriction. I just need to find one of my FJ friends with the TRD CAI and pull it apart and try it out on the 4Runner (ex: the TRD CAI tube on stock box. Or the TRD CAI lid on stock lower box)
In the post above your post, follow the link. In that link [MENTION=116156]TheWraith[/MENTION] is the member that had it tested.
Can you provide the link?
This is what I used for my application.
Also, I used my OEM paper filter because I didn't want to use an oiled filter!!
Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
Application:
Toyota: 4Runner 2010-
TRD Air Filter Lid Replacement w/clips
PTR03-35090-AA
TRD Lower Air Box Replacement w/clips
PTR03-35090-AF
TRD Replacement Intake Flow Accelerator for CAI
PTR03-35090-AC
TRD Replacement Intake Air Tube for CAI
PTR03-89100-AA
TRD REPLACEMENT coupler&clamp hardware kit for CAI
PTR03-89100-AB
TRD, Air Flow Monitor, Cold Air Int
PTR03-34071
Application:
PTR03-35090-AA
PTR03-35090-AF
PTR03-35090-AC
PTR03-89100-AA
PTR03-89100-AB
PTR03-34071
Ah, you picked it in pieces, well done. Thank you!
Application:
PTR03-35090-AA
PTR03-35090-AF
PTR03-35090-AC
PTR03-89100-AA
PTR03-89100-AB
PTR03-34071
Yep, a tried and true application that has been done by others..... see the link I supplied in an earlier post above ....
235.00 vs almost 400.00
Thats exactly my order. I didnt even think about the filter but will use my stock paper OEM for now and see how I like it.
