MudPie's DIY Center Console Organizer
MudPie
Having looked at all the others, I just wanted something simple to separate the things I leave in the vehicle from that which I regularly carry.
Supplies List
Corrugated Plastic Sheet
24 in. x 36 in. x 0.157 in. Black Twin Wall Plastic Sheet-COR3624BK - The Home Depot
Black Drawer/Shelf Liner
http://www.homedepot.com/p/Con-Tact-Solid-Grip-48-in-x-18-in-Black-Drawer-Shelf-Liner-04F-C6U51-06/100388906
Max Grip Carpet Installation Tape (Used to mount grip liner to corrugated plastic)
Roberts 1-7/8 in. x 75 ft. Roll of Max Grip Carpet Installation Tape-50-550 - The Home Depot
Scotch Mounting Tape (Used to mount rear support lip)
3M Scotch 1 in. x 1.66 yds. Extreme Mounting Tape-414DC-SF - The Home Depot
mudpie-albums-console+organizer-picture38325-organizer-grip-liner-applied-plastic.jpg
HOLY CRAP! That corex is expensive from Home Depot!!!
Just an alternative for those who have sign supply shops near them, you can get the corrugated plastic (in colors too if you like!) for less than that, considering a full 4x8 foot sheet is only $15.90, and a 2x3 piece is only $2.39 (I get mine from here)
And if you want something a bit stronger, try searching for "sintra", its a bit stronger, is not corrugated, yet still easy enough to cut with a utility knife. Its a bit more expensive, but does not bend or curl when it gets hot/cold.
Oh yeah, nice writeup on the false panel, I like it!!!:thumb:
i was just thinking about something like this to sit on top of the Salex organizer. Awesome. Thanks for doing the legwork.
Thanks for the tip on Sintra, I'll give it a try on my next project. :thumb:
