Elusive 15 TRDP/SW Build Thread
So that's where all the sand came from lol
Haha yea. Thanks for the rack and help with the install Victor!
Bought a Bajarack Utility Spy rack from [MENTION=44305]weeeee[/MENTION]
When I got the truck it only came with 1 key. Luckily it was the master key or else I wouldn't have been able to make copies, and if I lost it i would have lost it.
I ended up making 4 copies (excessive? possibly)
Got myself a Techstream MVCI cable from Amazon (https://www.amazon.com/dp/B00W97K7O6/ref=cm_sw_r_cp_awd_mTShxbRF492ZT) and struggled to get the correct software but finally got it to connect.
Ordered 4 G-chip remote key blanks and had them cut then programmed the transponders to the runner. Fitted 1 into a flip key housing and now I have peace of mind!
Awesome that you got it to work!
That flip key is pretty cool- mind sharing the details on it? Do all the alarm functions work?
Like it! I've done the flip key conversion but wouldn't mind a couple extra copies, even one that's just an ignition key without the remote. Mind sharing where you picked them up?
[MENTION=44305]weeeee[/MENTION] [MENTION=110651]reidbailey[/MENTION]
The flip key was also from Amazon https://www.amazon.com/dp/B011Y3MVEY/ref=cm_sw_r_cp_awd_0lThxb9663HEJ it is just a shell though. You swap the remote inners and transponder chip into the shell, get the blade cut and you're set.
At first I bought the wrong keys off of Amazon, when purchasing the key blanks make sure they are G-chip or else the 5th gen won't be able to communicate with the transponder. I had to order extra G-chip transponders off of eBay because of my mistake but it's helpful to know this is possible in case you need extra chips for any reason.
Here's the red key I purchased (this one is G chipped, comes in other colors) https://www.amazon.com/dp/B0192URXPI/ref=cm_sw_r_cp_awd_ssThxb9M4E2B2
If you search "Toyota G Key" on Amazon, you'll come up with all your options including the OEM Toyota key without remote
Thanks for the info!
Quick little detour on the way to dinner the other evening. Got a chance to get some flicks as the rig currently sits, with the Bajarack Spy I picked up several weeks ago from [MENTION=44305]weeeee[/MENTION] I've yet to order a light bar to mount onto the Spy system though.
Rainy day yesterday so my buddies and I went out to rip up some vacant lots.. tight donuts in 1st gear is something else :wow:
After a quick rinse this morning, I finally got to mounting a Viair 400P I won on Ebay for a generous discount! Figured the engine bay behind the air box is a better spot than taking up a cubic foot of precious cargo space in the back. Thanks to the write up by [MENTION=65614]Antman[/MENTION] I began relocating wires so make space for the compressor. I currently have the alligator clips in a bag tucked away on the side.
Now to figure out how to wire up a fuse box to run my lights and all the other fun accessories.
DSC04518.jpg~original
DSC04520.jpg~original
Mounted my Maglite 3-cell LED a few weeks ago. This mod is worth it's weight in D batteries!!
DSC04526.jpg~original
Viair 400P
DSC04527.jpg~original
DSC04529.jpg~original
DSC04530.jpg~original
DSC04531.jpg~original
Viair 400P
[MENTION=136976]elusive01[/MENTION],
I like what you came up with for your VIAIR 400P. I just ordered a 88P and need to see if I can do something similar.
For your question to figure out your how to wire up a fuse box to run your lights and all the other fun accessories........look here, see if this will help you: http://www.toyota-4runner.org/2342774-post69.html
[MENTION=103267]Saker[/MENTION] yeah man give it a shot, no wasted trunk space and it's a fairly easy mount with the original plate.
Thanks for the wiring thread, I'll check it out in a few!!
Looks like my VIAIR 88P install under the hood will be a no-go for a couple of reasons.....
Seems I'll have to wait on that with an upgraded unit.
88P will just have to ride in a bag in the back for now! :becky:
..Until then, ey?
Finally found the motivation to get the rig under jack stands and install this lift that's been sitting in the garage for a couple months!! I went to my buddy's house (who owns those 2 jeeps in the meme) to work on the rig. We were supposed to start at 9am but didn't get started until 1130 after dicking around with his jeeps and proper Summer Ale lubricants.
I went with Bilstein 6112 in the front and Toytec Superflex springs in the rear with the stock TRD pro rear res shocks. I bought the 6112 used from a FJ part out, he had a Toytec top mount that I opted to leave in. 6112 is on the 4th clip (1 down from top)
Along with those components, I rolled the dice on the JBA BJ upper control arms and definitely glad I did! Alignment tech was able to get my caster to 3.5* while keeping everything else in spec. Perfect.
Lift happened Saturday.. Alignment Monday, then I took off on a day trip to Yosemite NP on Wednesday. Got a few flicks after a good hike to the top of Nevada Falls via Mist Trail and a few more angles on the way out of the park. Very satisfied with the lift and first big drive. The ride's a tad stiffer than the stock TRDP, just as I wanted.
DSC05535.jpg~original
DSC05531.jpg~original
DSC05543.jpg~original
DSC05542.jpg~original
DSC05478.jpg~original
Then.. Sunday rolls around and I decide to take off again. 2 buddies and I head for the hills to do an overnight camp near Kirkwood, Silver Lake to be exact. Got there, went fishing for a little, cooked at camp, camp activities, then went for some Milky Way photography. In the morning we packed up, and drove around the lake where I found some trees I wanted to break in the lift and do a baby crawl.
DSC05563.jpg~original
DSC05570.jpg~original
DSC05566.jpg~original
DSC05558.jpg~original
Back on the highway headed home and I am keeping my eye out for roads off of HWY-88 when I randomly take an exit. I see a sign for snowmobile trails so I figure I go check it out, and we end up at an abandoned ski resort.. took a slope down to this awesome view where we were forced to turn around (or take a double black diamond plunge to our deaths). Pretty cool find, I hope I can find it on Google Maps so I can find out what this place was! **EDIT** I found out this place was Iron Mountain Sno Park.. aka Carson Ski Area. Very interesting stuff.
Iron Mountain, aka Carson ski area, last operated in 1995. Various persons have made attempts at reopening, without success. A caretaker was on the property as recently as 2003. The area now is adjacent to a Snow Park, popular with snowmobile riders. Buildings and lifts are still standing. Virtually all furnishings have been removed from the buildings. What's left is vandalized, all windows broken, doors left open to the snow.
Photos of abandoned Iron Mountain, CA ski area
DSC05576.jpg~original
DSC05582.jpg~original
DSC05585.jpg~original
DSC05587.jpg~original
DSC05588.jpg~original
DSC05593.jpg~original
DSC05598.jpg~original
DSC05603.jpg~original
I've had several PM's asking about the JBA UCA's and alignment.. yes they did help very much. We were able to push the caster angle up to 3.5* while keeping toe and camber in spec perfectly. I would recommend getting them, the install was a breeze, couldn't be any happier! :surfer::whoo:
unnamed%202.jpg~original
