Rigid Industries DOT Dually Fogs Installed
If you want to plug the Rigid D2s or DOT fog lights directly into the factory fog light wiring, you'll have to make the adapter yourself. You can no longer buy these. It's not difficult and you can buy all the materials on Amazon. [MENTION=116156]TheWraith[/MENTION] has a photo of ones he's made, and I modeled mine off of his. PM me if you need any assistance.
They really don't sell the harness any longer?
I thought that was the main selling point of buying a "plug and play" kit...
Picture request! Can you post a picture of the wire connects for the fog lights please? I want these but since my car is a lease I don't want to hack wiring. I want to get a factory plug if possible to make the light plug and play. Thanks!
We do have the harness in stock, as well as the brackets and all versions of the dually lights. Give us a call to get yours 702.979.1577, or check them out on Total Automotive Performance - Your Source for Auto Parts and Accessories - Homepage
Thanks!
looks like they have some in stock.
Thank you! I read that thread many times and still missed it. I'll try installing them again!
Adjusted the height so here's a better front view of where the tab is inserted in
Would this harness work? It looks like it would cost about $20 for the parts required to make the harness myself but for $30 I can buy it already made. Opinions?
Photos of Rigid Industries DOT/SAE fogs and Xenondepot 4300K HID
this set is from the middle of the console.
Camera setting:
F3.5
ISO 400
Speed 1/5
White Balance: Daylight
No lights
Rigid Industries Fogs only
[MENTION=12905]XenonDepot[/MENTION] Phillips 4300K HID only
[MENTION=12905]XenonDepot[/MENTION] and Rigid Industries Fogs
[MENTION=12905]XenonDepot[/MENTION] hid, Rigid Industries Fogs and High Beam
From the drivers seat. I'm 5'11 and position the camera where I would sit at.
Camera setting F3.5, ISO400, Speed 0.4", White Balance: Daylight
everything off
Rigid Industries LED fogs only
[MENTION=12905]XenonDepot[/MENTION] Philips 4300K HID only
[MENTION=12905]XenonDepot[/MENTION] HID and Rigid Industries LED Fogs
Driveway facing garage
Camera Setting: F3.5, Speed 1/13, ISO400, White Balance: Daylight
everything off
Rigid Industries LED Fogs only
[MENTION=12905]XenonDepot[/MENTION] Phillips 4300K only
[MENTION=12905]XenonDepot[/MENTION] Phillips 4300K HID and Rigid Industries LED fogs
depends, if you want to wire it directly with the stock fogs and use the stock fogs switch then you can either buy the harness or make it yourself. Or you can use the relay harness that comes with the kit
Any tips on aiming the fog lights? I installed the rigid lights and from driveway distance, my lights seem to be about height as your pictures/others who posted in the other thread. But when i back up or test it out on the street it seems like there's a lot of glare.
I took the lights out and tried adjusting the mounting bracket but it didn't seem to really help that much. And I tried searching online but it seems the only adjustments other people recommended was the adjusting the bracket. Thanks!
The only adjust there is really the bracket itself. I know Rigid has different options on the Dually's. Theres the Spot light Dually's, Flood light dually's and the DOT/SAE Dually. Which one do you happen to have?
I have the same DOT/SAE ones you got. Thanks for letting me know!
[MENTION=115334]Mistaken[/MENTION] idk if you are installing from underneath bumper or not. But if you are, I agree with Kevin and I found it much easier to remove 4 bolts from the wheel well plastic shroud and install from the side also. The driver side you could install from underneath but taking the shroud off helps a lot. And for the passenger side, you have to remove that plastic cover behind the fog light like sovat4r said in other thread. There's three tabs you holding it in, you can access it from the front fog light shroud (if you take out the white plastic chip above the back fog light cover so there's more wiggle room on the front fog light shroud. I have pics to make this make more sense and I can post if you want.
And thanks [MENTION=120150]TotalAutomotiveLV[/MENTION] for the adapter!
when I was installing mine the driver side was correct level and the passenger was pretty high up, it was hard to adjust the passenger side cause it was rubbing against the fog trim up front. What I did, I took out the plastic cover in the front of the bumper and adjusted and tighten the screw and then reinstall the front fog covers. If I remember I parked the t4r about 2-3feet away from garage door and the top of the fog beam was about 13-15" from the ground
