OPT7 42" LED Light Bar - DEAL!!!
4RunnerINprogress
Hey guys...I purchased the 22in OPT7 LED light bar a few months back to install with my behind the bumper mounts from @brad. I had the 42inch LED light bar in my shopping cart for awhile to add to my GOBI rack but hadn't pulled the trigger. Quality is pretty good for a lower end LED bar. There was just a price drop on it from $169.99 down to $103. I got one with my prime account and it came today. Just wanted to pass on a good deal for anyone looking for one. I will post up photos once I have time to get it on my GOBI rack. Trying to figure out how to run the wires. My rack is pre-wired but I don't want to run it all the way to the back tailgate. Need to figure out a way to run it down the front windshield into the hood.
Here is the LED light bar link:
https://www.amazon.com/gp/product/B00KJ17SOG/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
I got the same light bar on my Gobi, I had to widen the mounting brackets that came with the rack for the light bar to go in. The 42 in was just a bit too long, but its an easy enough fix with a drill/dotco and an arbor. I ran the wire down the windshield channel...easy install other than the slotting of the mount bracket holes.
Sent from my Pixel XL using Tapatalk
Can you post some photos of the bracket you had to modify? I wanna make sure I have all the parts before I start working on it.
I tried to take some pics but didn't quite work out. But check these out anyways, you just basically have to slot the mounting brackets about an extra 1/2 inch (i think it was a 1/2). You can also use the mounts that come with the light bar itself, I just decided to use the ones that came with the rack.
Hope that helps. You just need to make them go just a bit wider to accommodate the light bar width.
