Old 06-22-2017, 10:47 PM #1
jakerunner's Avatar
jakerunner jakerunner is offline
Real Name: Jake
jakerunner is on a distinguished road
jakerunner's Avatar
Real Name: Jake
DIY "Gobi Style" Roof Rack Build
After months of wanting a Gobi Stealth Rack for my 5th gen, but without the cash for one, I finally pulled the trigger...and built one.
Gobi is kind enough to provide specs on the material their rack is made of on the product page (16 gauge, 1 inch steel tubing) and the length, width, and height. This gave me a good starting point.
I drew it up in Fusion 360 just for kicks, and 3D printed a little model to get a look at it.
DIY "Gobi Style" Roof Rack Build-img_8661-jpg
DIY "Gobi Style" Roof Rack Build-img_2228-jpg
I bought 8 20' lengths of tubing, a sheet of 3/4" expanded metal, and some 6x6x1/4" plates. Also picked up some pre-punched weld tabs for misc mounting points. Total about $180
As for tools, I decided to pick up a pipe notcher from harbor freight ($50). Rather than buy an expensive bending tool, I made my own wooden bending jigs ($10), and they ended up working just as planned. These were mounted on a sheet of plywood and moved around, and I hand bent each piece around them. It gave me a good result for the simplicity, with very little flattening and no kinking issues.DIY "Gobi Style" Roof Rack Build-img_6296-2-jpg
I had access to a wire welder (much needed when working with the relatively thin tubing)
After getting everything cut, bent, and notched, I tacked it together to make sure everything fit and that I liked how it looked. The hardest part was the feet that connect the rack to the mounting points on the car. It took a lot of trial and error to get the mounting holes to line up.
Once I was sure everything was going to fit, I finished welding and cleaned it up with some grinding.
Planning on a coat of primer, followed by some some spray-on black truck bed liner.
Until that's done, lots of pictures!
Cheers
DIY "Gobi Style" Roof Rack Build-img_1784-2-jpg  DIY "Gobi Style" Roof Rack Build-img_7176-jpg  DIY "Gobi Style" Roof Rack Build-img_7012-2-jpg  DIY "Gobi Style" Roof Rack Build-img_5720-jpg
jakerunner is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 11:03 PM #2
YROC01 YROC01 is offline
YROC01 is on a distinguished road
That looks great! Nice job. I really like the 3D print. Netfabb?
YROC01 is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 11:03 PM #3
atchcraft's Avatar
atchcraft atchcraft is offline
atchcraft will become famous soon enough atchcraft will become famous soon enough
atchcraft's Avatar
That's awesome! The bender is the best part. I use 3D software, but im throughly convinced that 3D printers are a straight-up witchcraft! I love anything DIY, it's 1/2 the fun!
Matt
atchcraft is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 11:09 PM #4
jakerunner's Avatar
Real Name: Jake
jakerunner's Avatar
Real Name: Jake
I have my own 3D printer at home. Too easy
Old 06-22-2017, 11:13 PM #5
304tmt's Avatar
304tmt 304tmt is offline
Real Name: Travis
304tmt is on a distinguished road
304tmt's Avatar
Real Name: Travis
Great job. I want to make a flat rack like the baja rack.
Follow me on instagram @trailstandardoffroad
Dirt King 3.5 Inch Long Travel
No Idea amount of lift..
BF Goodrich KM3's 35/12.50R17
304tmt is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 11:13 PM #6
Off2Mtns Off2Mtns is offline
Off2Mtns is on a distinguished road
Love the ingenuity, especially the bending buck!!
Off2Mtns is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 11:49 PM #7
toppyjai's Avatar
toppyjai toppyjai is offline
toppyjai is on a distinguished road
toppyjai's Avatar
"If you build it... they will come"
2016 SR5 magnetic gray metallic / toytec lift / bilstein 5100 shocks / nitto terra grapplers g2 / scs f5 17x9 / SPOD / arb ckma12 compressor / baja spyrack / addicted offroad bumper / warn vr8000 winch / factor 55 prolink / rci metalworks skids
toppyjai is offline   Reply With QuoteReply With Quote
Old 06-22-2017, 11:53 PM #8
dorkmagus's Avatar
dorkmagus dorkmagus is offline
dorkmagus is on a distinguished road
dorkmagus's Avatar
I've been contemplating this. I think I may have to now! Do you have any close ups of how you mounted it?
dorkmagus is offline   Reply With QuoteReply With Quote
Old 06-23-2017, 12:15 AM #9
FrenchToasty's Avatar
FrenchToasty FrenchToasty is offline
Real Name: Morgan
FrenchToasty will become famous soon enough
MY GARAGE
Real Name: Morgan
MY GARAGE
Did you make the ladder aswell? You might be to cool for school!
I'm sure you'll get a cease and stop copying from gobi, but more power to you!!
2010 SR5 Blizz Pearl- Borla cat back, Firestone ride rite, Huskyliners, Afe Cai, Urd MAF, Gobi stealth with ladder, 5100s, icon 2" rear, toytec 1.6" front, TC UCA, HAF custom sliders, hand hold light mod, Led interior, stock rims and BFG KO2 265/70 C, Arb CKMA12- slider tanks w/ couplers, BD S8 10", opt7 40", BD dome light led in rear hatch
FrenchToasty is offline   Reply With QuoteReply With Quote
Old 06-23-2017, 12:33 AM #10
jakerunner's Avatar
Real Name: Jake
jakerunner's Avatar
Real Name: Jake
I can take some pictures of the mounting brackets tomorrow. I used the stock rack mounting points, and built some s-shaped brackets to connect that to the rack.
These brackets are probably the least-pretty part of my whole rack though. Long story short, I ended up having to mount the rack an inch higher than planned, so I had to add steel spacers to the bolts between the brackets and the rack. I will probably remake the brackets in the next 6 months just because, but figured I might as well wait and see what other problems arise after having the rack on there for awhile.
If you do decide to make one similar, shoot me a message, I can share some of the things I didn't think of the first time through and maybe save you a few hiccups.
-Jake
Old 06-23-2017, 12:37 AM #11
jakerunner's Avatar
Real Name: Jake
jakerunner's Avatar
Real Name: Jake
Yes I did make the ladder as well (I'm pretty proud it came out so well hehe). Functionality wise though, I may rework it, as it would be nice to have a little more room between it and the back door when climbing those rungs.
As for Gobi, so long as I'm not trying to sell anything resembling their products, I believe I can kindly tell them to leave me alone. I shall build whatever I want for myself.
Old 06-23-2017, 01:33 AM #12
mrluilou mrluilou is offline
mrluilou is on a distinguished road
the rack looks amazing Jake!!!
mrluilou is offline   Reply With QuoteReply With Quote
Old 06-23-2017, 07:17 AM #13
HeftyFJ40 HeftyFJ40 is offline
HeftyFJ40 is on a distinguished road
Wow. That's the best looking DIY rack I have seen.
HeftyFJ40 is offline   Reply With QuoteReply With Quote
Old 06-23-2017, 08:41 AM #14
dorkmagus's Avatar
dorkmagus's Avatar
-Jake
Thanks! I was planning on building one for my FJ80 but I sold it before I got around to it. Now with the T4R I'm back on the idea. I was planning on trying a conduit bender but if that doesn't work I'll use your "bender" idea. Nice work!
Old 06-23-2017, 09:21 AM #15
RaisedByWolves's Avatar
RaisedByWolves RaisedByWolves is offline
RaisedByWolves is on a distinguished road
Someone just won the Man of the Year award
Impressive
2015 LE
RaisedByWolves is offline   Reply With QuoteReply With Quote
WTB: 5th gen "Black" TRD pro roof rack end caps Notch46 For Sale: T4R Items 28 02-15-2019 05:33 PM
New roof rack to install; looking for details/pictures of mount areas to "silicon" Moving Chicane 5th gen T4Rs 21 06-27-2017 06:38 PM
FS - Thule Podium "Foot" Roof Rack System - Louisville, KY manderson1 For Sale: T4R Items 0 05-20-2015 04:28 PM
Full length roof rack 'Gobi style' drabbits For Sale: T4R Items 11 12-31-2013 05:16 PM
Copyright © 2019
