SSO Southern Style Offroad Slider Review
CS223
I finally got around to getting my SSO sliders installed. I said I’d post an update in another thread but I thought they deserved a thread of their own that would be easy to find in a search.
The SSO sliders were my third choice when I was shopping, knowing what I know now, I would have made them my first. Dollars to doughnuts, they were the best value. My first slider choice was nearly $1000 once shipping was factored in from the west coast, my second choice was part of a group buy that was slow to get off the ground and after no communication from the organizer after a week, I called it quits. About that time SSO put their sliders on sale for $499 delivered. I didn’t think much about the rock slider side of things at the time. Being a flat lander, I wanted them more for a running board alternative that would be easy to clean the mud from since I drive 2 miles of dirt road twice a day every day.
I placed the order online on Aug 11th, I wasn’t in any hurry, I had a vacation coming up and tons of other work on my plate. SSO emailed me & kept me in the loop, they had a manufacturing delay due to issues with the dimpling machine. I give them kudos for keeping me in the loop, I understand that stuff happens, most folks do. Keeping your customers informed is only good business.
They sent the shipping notification email with tracking on Sept 15th and the sliders arrived via FedEx Ground. The poor little driver asked me if I could unload them because they were too heavy for him. They were stretch wrapped, hardware was packed inside with them. They are beefy, I wasn’t expecting them to be quite as heavy as they are, specs say 56 lbs each.
They are mill finish, there are no other options for coating. They are beautifully welded and all parts are precision cut, I presume with laser as is SOP these days. Here are a few close up pics of various portions with them in the raw.
I didn’t have time to deal with them so they sat in the shop until I could block out a weekend. I called a local powder coater for a quote and they wanted $200 plus tax to PC them. It was too close to half the cost so it I decided not to go that route. Research kept coming up with the Rustoleum Bed Liner spray being a popular option so I decided to go with that. The local Lowes stocked it, and the ease of future repair appealed to me. Next was deciding how to prep them. Since I had access to a pressure-pot sandblaster I decided to go that route. I tried some run of the mill sand then tried Black Diamond which is coal slag. Tractor supply stocks it and it was relatively cheap. I bought the Red Bag Fine grit. $8 for a 50# bag, it took 5 bags with some left over. I used 50-PSI of air pressure and it took me a couple hours total including the leg work, interruptions etc. The finish was just what I wanted just coarse enough to give the paint plenty of bite.
cs223-albums-sso-picture48437-fine-grit-use-1-8-nozzle-used-50-psi-air-pressure-pot-not-siphon-style-sand-blaster.jpg
The next hurdle was how to hold them so that I could spray them all at once & not have to handle them risking messing up the finish. I ended up attaching a 2x6 to the top of my ladder, I added eyebolts that were double nutted above a flat washer. This gave me a swivel so I could rotate them toward the light. I added a short length of chain & a hook This allowed me the room to get at each end; high enough to get underneath and a step up the ladder to get the top. Had to get someone to stand on the ladder until both were hung. I also put a furniture dolly under one side of the ladder so that I could pick up the other side and roll it out of the way while they dried.
They are advertised as bolt on and they truly are. I popped out 3 of the frame plugs each side that would have been behind the plates and I took off the little plastic tabs at the rear of the rocker. I put a board and piece of cardboard on the floor jack and centered them up so they were balanced. I removed the bolt from the e-brake cable clamp. It was just a simple matter of jacking them into place, starting all the provided bolts and then tightening them up. If you have some mud time on your T4R, you'll want to blow out the bolt holes to clean the threads. There is an opening on the rear plates for the tab on the e-brake cable clamp so no need to bend them flat or cut them off. I torqued all the bolts to 30 lb. There were no fitment issues, no a single cuss word. Probably took an hour total to install both.
SSO makes use of all factory provided mounting holes, no drilling, no fishing hardware through the frame etc. Each mounting plate uses 4 fasteners and spreads the load over a wide are of the frame, this was very well thought out. Their boxed & gusseted supports are a departure from what others use. A feature I wasn’t sure about until I saw how well engineered they are. The provide an added measure of protection underneath and being angled, they should reduce the chance of hang ups on obstacles for you folks who use them as intended.
The sliders fit up snug under the rockers with enough room to clean out the mud that will accumulate, ends are tapered front & rear, again to prevent hang-ups. Initially in my slider shopping I found the angled lines of the kick-outs used by various manufacturers more attractive but after seeing the SSO’s installed, I like the looks of the curves more as they seem to blend better with the curves of the body style. The over all look is very subdued, less obtrusive than factory running boards of either style. They provide just enough toe hold to aid in getting in & out of the vehicle, they don't stick out so far as to whack your shins. I was a little worried they wouldn’t stick out far enough to protect against the door bangers but a quick check with the level shows that there is about 1/2” give or take protrusion beyond the body side.
Overall a very well engineered product, I’m very impressed with the thought & detail that went into the design and the level of customer service with my experience.
Now they just need to make a bolt-on no-cut front & rear bumper……..
Wish they didn't increase the price of their sliders to $599 plus shipping now. Guess I'll wait for an All Pro group buy instead.
And yes, its been parked in the shop with 26 miles on it waiting on me to get the sliders done & installed. It''s no fun working underneath with clods of sand and mud falling in your eyes. Now I can finally drive it.
Nice review. You beat to me posting my review. Overall I am pretty pleased with mine too. I will have to get my review posted.
I installed mine yesterday. I got in on the $499 shipped Labor Day deal. It was too good to pass up. I seen these sliders earlier this year at the FJ Summit and knew these were what I wanted (already owned some RCI sliders). The build quality is top notch without a doubt. However, my install didn't go as smoothly as yours. I did a lot of cussing. The driver's side holes didn't want to line up at all. It took a lot of work and force to get all the bolts started in (didnt tighten any of them at first). Once all the bolts were started in, I torqued them down, but you could tell they were in a bind. The passenger side was much easier. Holes lined up very well. Overall I'm very happy with them.
Look like the tried and tested RCIs that have the bulge in the back and they have the step inserts in them like the HF (Harbor Freight?) I've been seeing around the Springs, but with much better weld quality.
It's a crowded market, but these seem to look nice.
Also mill finish only when similarly priced competitors are offering high end finishes for not much more $$$?
Nice write up, very informative, thanks.
I also got in on the recent sale and mine were delivered this week. My inspection yields the same results as yours, they are very well designed and the craftsmanship of the fabrication is top notch.
Fortunately powder coating prices aren't so bad here and I'll be hauling them to the shop tomorrow. In a week or two after I get them installed I'll do a follow up on how that goes.
