21mm sway bars?
Gen5: 19mm or 21mm Rear Sway Bar Bushings?
I have a 2016 4Runner Limited and I measured 21mm near the end of the bar, then measured right at the current body mounts and got 20-20.5m. Then I pushed a Whiteline 21mm W21105G bushing on the bar next to the current mounting point and it fit easy with no gap.
Made me think the bushing might be too big as it rotates easy but I don't see any gap at the cut side so maybe when installed and tightened down it will be OK. My guess is a 19mm or 20 mm bushing will also fit but the 19mm might have a narrow gap showing on the slit side which should not really matter.
Progress4M - Thanks!
I can confirm the 2016 4Runner Limited I own has a 31mm front (1.22 inches) front sway bar and a 20mm (0.787) rear bar.
I bought a set of Front Sway Bar Bushings - 29mm (1.14 inch) made by Whiteline, Part Number: W23432, based on this forum and the Amazon Web Site that I do not intend to use, if anybody wants it. I ordered a new bushing set with bracket for a 31mm bar.
I also have 21 mm rear Whiteline bushing set if anybody wants it as I re-ordered a 20mm set.
At least I finally have this straight.
sounds like you have X-REAS?
I have a 2018 SR5 and it has too much body roll while cornering. Can the sway bar be replaced with the larger diameter units as found on 4Runners with KDSS?
Any ideas on where I can get a larger diameter sway bar?
Thanks!
Hate to revive an old thread, but I’m curious if you still know the whiteline part numbers you ordered (31 front and 20 rear). I’m doing some more work on my runner soon and have read these improve sway… not sure if it’s true, but for the price, it may be worth trying.
