Bilstein TRD Pro suspension kit on sale PTR13-35140
Another before and after....went and found the same spot from an old photo haha.
Hey twins! We got mine installed today. I would have been dead in the water if it wasn’t for [MENTION=105450]CowboyTaco[/MENTION] . He has the patience of a saint to be able to put up with my noobness. Went with the daystar 1.25” isolator in the front and wheelers T13 coils in the rear. Butter smooth and no more nose dive.
Hey twins! We got mine installed today. I would have been dead in the water if it wasn’t for [MENTION=105450]CowboyTaco[/MENTION] . He has the patience of a saint to be able to put up with my noobness. Went with the daystar 1.25” isolator in the front and wheelers T13 cools in the rear. Butter smooth and no more nose dive.
Patience comes easy when the company is good. Glad I was able to help!
I just installed this kit on my trail with kdss. Everything was super easy. To mount the rear reservoir I used a rivnut. The truck feels like a truck now. For the money it’s a killer upgrade.
Could you post the type of rivnut you used? I grabbed one from ACE hardware that looks like the picture below but it wouldn't fully go through the hole in the frame. Do people drill through the back side of the frame as well?
Looking to mount the remote reservoir on 2018 TRD ORP.
Hans
I work at a company that makes and buy springs all the time. I am sure I can find a 15" spring with 3" ID and a 600-700lbs spring rate but will it work?
I think it might be too risky at the moment
Sign me up if you can find 15x3x600 lbs springs.
Have you installed yours yet? Just got mines and looking for someone to help withcthe installation or a cheap 4x4 shop to do it
Anyone has installed this kit and willing to help in the Seattle are.. I have turn a wrench before but not comfortable enough to do the install by myself
Only one side of the frame is drilled.
See post #230 and #713
Which years KDSS don’t have the threads? My 2010 has threads.
Stupid upside down pics as usual
So I have a 13 Limited that I just picked up and was thinking of getting one of these kits. I've read all the pages and didn't find an answer. Does this kit work well on the limiteds? I was going to order 5100's but this seems like a better deal to me.
Just ordered from Toyota Parts deal. Only ones that I could find that had any left.
Paid a little bit more 604 shipped. Still a good deal. My 2018 Sr5 is going to be happy:cowboy:
Finally got mine installed and LOVE it. Enormous difference from stock.
Full setup:
- FJ TRD Kit
- 1.25" Daystar Preload spacer in front
- 1" Dobinsons 599 coil in back
- 275/70/17 ST MAXX tires
Did you take measurements on this? It looks jacked at the front.
I'm planning to use the TRD Pro 1" lift from Toytec on the front and 1.5" spacers on the back for a total of 2"F/1.5"R from stock 2016 SR5.
1" Front Lift for TRD BAJA and Pro Edition Tacoma & 4Runner
Rear 1.5" lift Black Spacers Poly for FJ/4Runner
Anyone running that setup?
Jon
I forgot to take before/after. I can take center-hub to fender measurements tonight. I should be around 2.25-2.5" in front and 1-1.25" in back
I could be missing something
First off, picked up my T4R Off Road Premium this last Friday but I have been following (lurking) for about 9 months now. Finally pulled the trigger over Memorial day weekend.
I had been following this thread and read/skimmed most of it, and others, ordered this kit, should be here in a few days, thank you to the OP and others. For all this fine knowledge.
But I have one question, with a few parts….
1. The rear mounting for the resevior, seems my T4R many not have the mounting holds threaded (2018 Off Road Premium) so I will have to do some sort of RivNut or something to mount. I understand that, if so
2. Do the rear mounting brackets and clasp to mount the remote reservoir come in the kit or do I need to purchase separately? Most of the pictures of the kit don’t show the brackets that I can tell. If so
3. Has anyone confirmed these (Bilstein 11-176015 B1 (Components) 5160 Billet Reservoir Clamp - Shockwarehouse.com ) will work or not on these diameter shock bodies?
The rear reservoir mounting brackets came in the kit.
Untitled by Matt Proudfit, on Flickr
Full setup:
- FJ TRD Kit
Your lift came out perfect with the daystar preload spacer and Dobinson rear spring.
I have the same setup minus the rear springs. I have the Toytec Superflex springs but I'm assuming I will achieve the same lift as you after install.
Now I just need to find the time to install everything
