03-09-2018, 12:57 PM
#16
It does look beefy.
What is the weight of this bumper cover with all the arms attached... also. why leave it hanging low in the corners when that can be tucked up quite a bit.
Any plans for aluminum version?
03-09-2018, 01:27 PM
#17
Having the gas cans fully enclosed with only a top lid for access is a bad idea. Not sure if these are compatible with only the NATO metal cans but Sceptre MFCs bulge a bit under temp or elevation. With the lid like that it doesn’t allow the user to vent the can in the holder. Also having the lid on top only is going to make it difficult to take a full can out because it needs to be pulled straight out under expansion.
Other than that minor gripe, good job Pelfreybilt! Bumper looks great!
IG @go.xplre
03-09-2018, 01:29 PM
#18
Originally Posted by weeeee
Having the gas cans fully enclosed with only a top lid for access is a bad idea. Not sure if these are compatible with only the NATO metal cans but Sceptre MFCs bulge a bit. The lid like that doesn’t allow the user to vent the can in the holder. Also having the lid on top only is going to make it difficult to take a full can out because it needs to be pulled straight out vs. wiggled our under expansion.
You can just burp the can. But I’ve also suggested the cans swing up from the back so that the top and front are one piece.
I don't own a 4Runner anymore.
03-09-2018, 01:35 PM
#19
Originally Posted by wfo9
It does look beefy.
No plans for aluminum. Weight is 200lbs with the arms. But we will know an exact number soon.
03-09-2018, 01:41 PM
#20
That will be key. Because if the MFC is expanded enough to bulge you won’t be able to get the cap off by hand. And looking at the pics it appears there’s no way to vent with a wrench. Just a suggestion so we can avoid a completely stuck can in the holder.
IG @go.xplre
03-09-2018, 01:42 PM
#21
the wait is coming to a end soon! preordered november for the base bumper. Just a bit longer!
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
03-09-2018, 01:49 PM
#22
The carrier swings down from the bottom. Will post a photo when I’m not on my phone. But this won’t be an issue.
03-09-2018, 03:40 PM
#23
You're absolutely right, and remember that outside of the prototypes in progress I was going by the CAD drawings. Those drawings are over a year old, which gives an idea of how long this thing has been in progress (2 friggin years!)
Anyways based on the CAD it clearly looks like the top opens. And as a result to your point I hit up Tyler, who sent back the following photo. It opens from the bottom, so removal should be easy if you need to get the SCEPTER wrench on it, and the sides are built to allow for some flex so it doesn't bind up completely.
Hope that helps with some questions:
03-09-2018, 11:47 PM
#24
Originally Posted by JohnTheLuck
Bah, just give it to me and get the new one !!!
Sorry, but I cut my rear cross member out so this is the only bumper that currently works. Wah Wah Wah Waaaaaahhhhhh.
03-10-2018, 02:48 AM
#25
If I only had the cash.......
but yeah, good job pelfrybuilt(sp)
03-10-2018, 03:39 PM
#26
I just bought your Front bumper
2017 4Runner Limited Blizzard Pearl w/3rd row
TRD Pro 17" Black wheel with 265/70/17 Goodyear MTR
TRD Shift Knob, TRD CAI, MagnaFlow cat-back exhaust, TJM 3" lift, All-Pro APEX Sliders,(waiting to install Pelfreybilt Group 31 battery cage, NorthStar Group 31m Battery, Pelfreybilt front bumper, Warn 9.5xp, Baja Design S8 30", Baja Design Squadron Sport Fog lights, Switch-Pro SP9100)
03-12-2018, 01:37 PM
#28
Originally Posted by pelfreybilt
Michael,
Are you confirming pre-orders? I sent you an e-mail last Thursday...
Thanks
03-12-2018, 02:14 PM
#29
Real Name: Pelfreybilt
Originally Posted by comtn4x4
Michael,
Thanks
Sorry about the delay in response. Our team is very busy right now and occasionally an email slips through the cracks. Could you PM us your email address? I’ll confirm we received the email or if it accidentally made it to the junk folder.
Thank You for your patience!
-Pelfreybilt
Pelfreybilt - High Quality Off-Road & Overland Toyota Components
03-13-2018, 05:16 PM
#30
Here is the Pelfreybilt Corporate Cruiser rocking the non-swing-out version finished off with a set of Baja Designs S2 Flush Mount Lights ( available here on our site).
Available for $1499.99 ($1674 Powder Coated)
Note: Lights not included
To Pre-Order please see the first post on page 1. Thanks for the orders!
-Pelfreybilt
www.pelfreybilt.com
