Real Name: Chris
Real Name: Chris
Wheel fitment help - 17x8.5 - 0 offset -will it fit? should I go with different size?
Hey guys,
I have a TRD Pro with a front 1 inch leveling kit on it with spidertrax spacers and 265/70/17 Ko2.
I found a set of method con6 that I think would look great at is 17x8.5 zero offset and 4.75 backspacing.
Will this fitment be similar to my current setup with the spacers? Obviously the wheel is a little wider, but what about the actual stance? Will the 265 tire now look tiny as a result?
Or should I size up to an 18 inch wheel to get some better tire options?
Thanks,
Chris
