Designing a PCK for the 5th Gen, need some input..
Wow - you guys almost bought out the run overnight! I've only got 2 left unspoken for of the initial run as of this morning!
We're still on track for our delivery ETA, but I just wanted to share that I've just learned the the 5th gen kit fits the 4th gen also (and apparently the FJ and whatever Lexus is on the 120 platform?)
Very exciting.
I'll definitely increase the order size tomorrow.
Been watching these on the 3rd gen for a long time now. I'm too busy at the moment to get around to one of these but maybe a good time to buy. In to see some pics of a 4th gen fitment! Good work!
Have these shipped yet??
Thanks! We're looking at 3 weeks until I can ship this first batch; then I'll get some more coming.
Nope, but we're still on track for an end of week pickup from the bend shop.
My estimated ship date was 8/6, so we're still looking good for that, however two of my other orders this month have come in a couple days early, so we may get lucky with these, also.
Ok guys, the bend shop confused a couple of my orders and only made 10 kits for the 8/3 pickup. They’re going to expedite the rest, but it’ll be another couple of weeks on the balance of the run.
I’m going to start emailing you guys, starting with those that signed up first, to see who has a critical timeline & who would be willing to wait on the rest of the order so that someone else who has scheduled a welder or has a window of opportunity for their install can get their kit now, ok?
Sent from my iPhone using Tapatalk Pro
Also; here are some installation photos!
This is the PCK - this bracket and a nut makes up the kit!
First thing you want to do is pull the panhard bar and move the wire that is clipped on the inside of the existing panhard bar mount - it'll go back on the opposite side of the mount when you're done.
The PCK should be a pretty good fit right out of the box, but minor trimming will be necessary from truck to truck. Here's how this one sat intitally:
On the front side (the side toward the spring) some trimming was required to get it to sit flush & level - you can see a minor gap to the passenger side of the wire tab; this is perfectly acceptable. I did minor trimming on 4 spots on the PCK to get this fitment (about 6 minutes, altogether.) I also trimmed the flange that was touching the brake line to give it clearance, then I pulled the brake line over to the spring with a couple of zip ties to give me room to weld back there.
Once you're happy with the fit, chamfer the edges on the weld-side. The inner faces of the PCK are 50mm apart, like the factory bracket, so align the inner faces with the factory mount. Since the PCK is made of heavier material, it will sit a couple of millimeters proud of the factory mount on the outside face.
STOP AND DISCONNECT THE BATTERY BEFORE WELDING.
Weld it up & paint it with your favorite brand of flat black (I used rust converter on the factory metal first, due to its condition), bolt in the panhard bar with the nut included in your kit (I used blue loctite on both panhard bar bolts), attach the wire clip to the outside of the bracket and you're good to go!
Update
Hey guys, just spoke with my bend shop today, and the remaining PCKs have been cut and are in line for bending.
I should have an update on Monday - have a great weekend!
Hey I ordered a set yesterday, can you give us an update on when recent orders will ship? Thanks.
I just got the call from my bend shop; I'm picking up a gazillion PCKs in the morning and will start shipping out in the afternoon!! :)
Every order will ship before the end of this week. :dancin:
