Ram Mount setup in my new 2018 TRD Pro
jcage89
I had a Proclip phone mount setup which worked great in my '06Sport that I just sold with a bolt-on bracket that situated the phone in the joint between the glove and the the climate controls with the holder facing the driver seat. This is ideal for me because I don't like my phone in my face when I'm driving but do want it easily visible and within reach to use while stopped. I also don't like suction cups and such. Unfortunately, the Gen5 interior is different and Proclip doesn't make a mount that will work in my new TRD Pro like in my '06 sport.
I have been searching posts here and found the RamMount to be popular. People here have shown many ways to mount it from a clip on to a mount on the floor in the passenger seat foot and none of these are ideal for my preference. I did find a post that linked a write-up by Trail4R.com here...
https://trail4runner.com/2018/01/23/4runner-phone-mount-5th-gen/
and associated Youtube by SnailTrail4x4 here...
https://www.youtube.com/watch?v=730MzCb1qfA
Credit for this great idea and write-up goes to these guys BUT it still wasn't ideal for me because (1) it puts the phone right in your face up by the wheel but also of concern to me (2) you are drilling into a piece of plastic trim that is actually not available by itself according to multiple parts distributors. This location shown in the Youtube is actually a trim piece only available as part of the nav/head unit assembly and only replaceable by purchasing that whole assembly at an insanely high cost if you ever want to revert this install and go back to stock.
So this writeup did give me the idea that I could probably do the same thing but situate the mount over by the glove like in my '06Sport with the Proclip mount. Ichecked the location with the RamMOunt and noticed there was room and actually the glove door on my new TRD Pro is notched right there which allows the glove to open and clear the arm on the Ram Mount. Also all button/knobs are still easily accessible and the setup doesn't get in the way of a passenger sitting in the front seat.
With this in mind, I researched the plastic trim piece (right side pillar) which is super easy to remove just by carefully pulling away from the console. And this part (Finish Panel 55012-35050-C0) is available online for about $75 if you care to purchase a spare and be able to later UNDO the install.
Here is pictures of what I did (note that I used the exact same Ram Mount and mounting bracket parts detailed in the links above so I won't repeat them)....
First I lined everything up where I wanted it and made sure it didn't interfere with the glove door. I market the location with a piece of painter's tape.
Next I got a little furniture foot glide sticky thing and put it on the inside of the drill location to approximate the size of the head of the bolt and washers to check that it cleared the console frame parts when I put the trim piece back on.
After lining everything up and confirming the fit, I drilledsmall pilot and then enlarged to fit the bolt just like in the video. Again CAREFULLY and SLOWLY because it's just soft plastic.
Then just simply bolt in the mount through the trim piece (I used a lock washer in mine in addition to the same washer they used in the video) and put it back together.
Here it is with my phone the way I like it and been driving around for a week this way so super solid and works great for me.
Here shows how the glove door notch clears the mount arm.
Hope this variation on the idea of others helps even more of you and thanks for all of your great feedback and ideas that I get here all of the time.
Cheers and Happy 4th to you all!
:bowl:JC
How do you get your phone in or out one handed? I have mine mounted higher on the left side of the console and haven't figured a way.
semi related note. I saw a post recently about not wanting to mount anything near this location because of the passenger airbag deploying and potentially throwing a hard object at someone. Is this a valid concern? I have a ram mount (aluminum bendable stick kind) under the front bolt of the pass seat and was thinking about this the other day. These do deploy with some serious force. This video is not a 5th gen but they are all pretty comparable.
https://www.youtube.com/watch?v=RgFya3WVViw
I just hold the phone in left hand and pinch the two prongs on right side stick it in there and let go. Seems easy to me but maybe not understanding the question. Cheers JC
Yeah good point. I don't think the passenger Airbag will deploy without a passenger sitting there so only an issue when someone with me and I'm driving it alone 90% of the time except familyroad trips. In that case I should look into whether having it mounted that low would make a difference in the safety concern. Anyone here know more about this?
Cheers,
JC
Cheers,
JC
Found this video showing the passenger airbag deployment on a 2012.
https://youtu.be/wVXcbklGsSs?t=1m24s
I had Pro Clip's vent mount in my T4R for a while. Worked great except for blocking the driver's side vent. I recently switched to an Expedition Essentials T4RPAM unit, it's awesome. If you're willing to drill into the dash pieces, why not go big...lol
Seems like the airbag would cause that tablet to be a projectile.
Wow cool thanks. Looks to me like the passenger bags deploy in a way that kind of avoids that area with the direct forceful deployment but could be misleading by the slowmo. The trim piece my phone is mounted to is dislodged but of course the rig is hitting a brick wall at whatever speed. My mount would probably come off around the passenger's leg area but with that deployment looks like it is not hit directly by either the upper or lower bag. There isn't anything pushing out from right behind it. I suppose it is not as safe as it could be but seems to me like anything in the cabin could pose a similar risk in that situation. As far as mounts go this would apply to anything suctioned in the typical dash/console areas and certainly the mounting locations higher up would be of concern to me as possibly being launched into someone's head area.
Not sure without a similar video showing what happens with a phone mounted there during a crash but seems like it does not substantially increase the risk over everything else happening in that situation. Only other thing to do is totally empty the cabin of anything attached to trim or loose sitting on console or door pockets. That just doesn't seem reasonable or how the car is set up to use in daily life.
Thanks for the feedback all.
JC
Living in Arizona makes it impossible to have anything mounted that high. Unless you have heavy tint on the front windshield or CRANK your AC everything overheats way to quick! Even my tablet that's mounted by my shifter overheats.
