TRD PRO Skid plate = not so strong
Jetboy
I need to do a trip writeup, but I've been busy since I got back. But I thought I'd share this. One trip through the Rubicon - 3 short days of rock crawling - was enough to destroy a TRD Pro skid plate. What you'll notice is that it bent in the middle, broke both welds on the outer sides, and if you notice the mounting points - one of them showed significant plastic deformation around the mounting point.
I did not feel like I was very hard on it. My setup this year was about 1.5" higher than last year (taller setting on front coilovers and 34" tires vs 33's last year). I did not feel any major impacts that should have done this much damage. I'm a finesse driver. I'm not afraid to break stuff - but I try to do it as gently as possible. You can see that there is pretty limited rock rash on it. I think the plate is just not very strong.
I do recognize that I significantly compromised the sides by cutting away for the KDSS sway bar. Either way it still would have been pretty much ruined give how much it bent in the middle and the mounting points nearly failed.
My general opinion is that the original steel skid plate held up a lot better. For long term abuse over a decade - the steel one is going to do a lot better job of protecting the engine in the long run. Overall the aluminum skid is a downgrade in terms of actual functional protection. But it looks pretty cool!
Also - for those who are using them I would suggest getting some 1/4" thick heavy duty washers to put between the skid and the mounting points to spread the load more. The aluminum is not strong enough at those locations to withstand moderate impacts. The welds on the sides also have limited penetration. I would re-weld them on the inside to get a full penetration. And I might consider additional reinforcements along both the sides and the center pan area. I think the skid could be pretty easily reinforced to fix the weaknesses with some pretty easy to add reinforcements.
The Skid did do it's primary job. Nothing was damaged that it was protecting. For that purpose - it did work. I'm disappointed. I thought it would last better than it did.
My plan now is to make a clone of the TRD Pro skid (I like the way it looks) in 1/4" steel using the PRO skid as a model. I hate the weight - but I gotta have something stronger. I don't have time to swap skids after every trip.
No one should be disappointed in the OEM Aluminum skid when traversing a heavily loaded 4Runner across three days of rocks. Better to have installed 3/16" steel skids before going and sold the TRD skid instead of destroying it.
In no way are the factory steel skids much better. Way too thin.
This is my second trip through. The factory steel one got dented, but otherwise held up okay. I think it's a better engineered skid than the TRD Pro aluminum one overall. But... neither are really built for repeated runs over the rocks like that.
The 4runner handles the trail like a champ though. Got turtled on the gas tank a couple times. Otherwise pretty smooth sailing. Overall the durability of the 4runner has been really good. It's hard to build a useful spare parts kit when nothing ever breaks. I still carry a spare axle set, but I've yet to use it. Wheel base and width work great.
The sliders put in a lot of work though. I made some temporary slider bump outs that bolt on to my sliders because I ran out of time to bend up some new ones. They saw a lot of rock time... but worked great.
I went with the TRD PRO skid purely based on the looks and knowing I would need to replace it every year or two. Looks great, not so strong but I was impressed with it being as good as it is as an OEM part.
I've learned to pick a better line...
3/16" steel or better for rock crawling. Definitely should've sold the TRD Pro skid when you started rock crawling. Function >form
Probably should be taking my rock crawler instead of the 4runner :) but I'm not sure it would be as much fun in a real rock crawler. I don't think it would be very challenging.
The 4runner really is remarkably capable considering how well it does as a daily driver.
This is why armored vehicles with aluminum "armor" don't live long. Steel is better. :)
Sent from my SM-N950U using Tapatalk
At the end of the day, as long as you got some good pictures with that skid plate on, that's all that matters. form > function I say!
Its really hard to judge without knowing exactly what its been through but based on your experience/knowledge its a good data point - FWIW my RCI skid has not faired that much better, welds are cracking, large bends/dents and the bolt head protectors well one is missing and the other is barely hanging on (basically a horse shoe welded to the bottom of the skid) but If I get to the point of no repairs I will buy again - hate rust
Like you said - it did its job
I know you said after your last trip you didn't have many pictures because it's almost constant obstacles and you don't want to be that guy holding up everyone for pictures, but did you get any this time?
That's awesome that the 4Runner does so well. You're obviously a good driver, but I still don't get it. If you read about the Rubicon online it's nothing but horror stories of blown ring and pinions, destroyed body panels, gernaded t-cases, etc. Yet, you've gotten a somewhat mildly modified 4Runner through twice, and Jeep somehow gets Cherokee Trailhawks through. I think Jeep has an army of rock stackers, and could probably air lift out a busted vehicle, but I'm assuming you don't have a rock-stacking army with you.
I feel like I've done some challenging trails in Moab, and the vehicle is obviously very capable, but I'm still impressed.
Normally the weld is stronger than the metal, not sure about aluminum, but it looks like it did not get very good penetration, and should also be welded on both sides. Like others are saying though, if you are a rock crawler, steel is a better choice.
Agreed. It’s honestly why I got away from my 37”+ tired rockcrawlers, they take the challenge out of the more mild stuff which is the majority of trails I run.
I almost bought a TRD skid thinking it will be fine for my uses and I still think aluminum is, but will go with RCI after seeing that words on yours. Yikes.:eek:
